Painting videos
This section contains videos about DIY painting.
Painting can be difficult, especially if you do not know which paints should be used on which materials. Here we have videos showing how to paint common DIY materials such as tiles, metal and MDF.
  • 10:23 Popular How to paint a garage door using the Wagner Flexio sprayer
    by Admin Added 390 Views / 0 Likes
    In this video I spray two garage doors using a Wagner Flexio 590 sprayer and Zinsser Perma-white exterior paint. It is well worth using a sprayer as the quality of finish is absolutely superb, I know it can be time consuming masking everything off but the
  • 07:32 Popular How to paint over wallpaper | Zinsser wallpaper cover-up
    by Admin Added 800 Views / 0 Likes
    In this video I paint over some kitchen vinyl wallpaper using Zinsser 123 as a primer, followed by two coats of Zinsser Perma white, which is mould and mildew resistant. Blown vinyl on the landing is also painted over using Zinsser wallpaper cover up, as
  • 04:38 Popular How to fix a rusty corner bead
    by Admin Added 1,498 Views / 0 Likes
    A rusty corner bead or a rusty angle bead can be a real problem to fix and must be done correctly because if you try to paint or paper over it without fixing the rusty bead first the rust will eventually come through the paint or paper. This video shows h
  • 06:38 Popular How to prepare a damaged wall for painting
    by Admin Added 1,585 Views / 0 Likes
    Plastering a wall with a skim coat of plaster should always be a last resort as it can add days to a job by the time the plaster has dried enough to be painted. This video shows how to prepare a badly damaged wall and make it look like brand new.Firstly t
  • 05:26 Popular Zinsser Gardz | Drywall sealer/primer
    by Admin Added 818 Views / 0 Likes
    Zinsser Gardz is a high performance sealer that can repair damaged drywall or lining paper, it can also eliminate bubbles. This primer can also be used to seal skim coats of plaster, can be used to prime drywall/plasterboard giving it a hard and durable f
  • 03:46 Popular Gyproc Easi-fill | Gyproc Easi filler
    by Admin Added 1,493 Views / 1 Likes
    Gyproc Easi-fill was originally made for filling the joints between sheets of plasterboard or drywall once they had been fixed to the wall using the direct bond method. I know decorators that have been using it as a filler for years and now Gyproc have re
  • 03:36 Popular How to paint a metal radiator
    by Admin Added 1,540 Views / 1 Likes
    This video shows how to paint a radiator using Zinsser perma white. There are three separate radiators in this video, one is in a bathroom, which is rusty at the bottom. This radiator is sanded to remove the rust, then treated with a rust convertor before
  • 04:46 Popular How to paint a yellowed kitchen ceiling
    by Admin Added 1,212 Views / 1 Likes
    When painting a kitchen ceiling it is critical to choose the correct type of paint or else you might find that it needs repainting much sooner than you thought. In this video I clean a dirty, yellowed ceiling and then paint it with some Zinsser cover stai
  • 03:19 Popular How to repair a crack in a wall
    by Admin Added 1,463 Views / 0 Likes
    Cracks can often appear in plastered or drywall walls due to settlement or slight movement. In most cases the cracks are nothing to worry about and are only cosmetic. These cracks in the plaster or cracks in the drywall can easily be fixed using a suitabl
  • 10:27 Popular Zinsser ALLCOAT | painting timber
    by Admin Added 1,378 Views / 0 Likes
    Zinsser ALLCOAT is a unique paint that is a primer and top coat combined. Simply apply the first coat (which acts as a primer) then apply a second coat which becomes the top coat. Zinsser ALLCOAT is water based and very quick drying and can be recoated in
  • 06:46 Popular Mirka Deros review
    Mirka Deros review
    by Admin Added 1,443 Views / 1 Likes
    The Mirka Deros is much better at sanding than traditional sanding machines. This machine is much quitter and easier to use than most other orbital sanders. The Mirka Deros can also be used with either the 125mm pad or the 150mm backing pad making this ma
  • 02:51 Popular Rustoleum Rust Reformer | Paint rusty metal
    by Admin Added 1,582 Views / 0 Likes
    Painting rust metal used to be a difficult and time consuming job. Now it has been made much easier with special primers such as Rustoleum's Rust reformer. Simply brush off any loose rust using a wire brush, wipe clean with methylated spirits and then pai
  • 05:53 Popular Painting metal using Rustoleum
    by Admin Added 1,451 Views / 0 Likes
    When painting metal you can acheive the best results by cleaning the metal before applying the primer and then the top coat. This video shows how to get good results using Rustoleum spray paint.
  • 01:12 Popular Paint brush and roller care
    by Admin Added 2,145 Views / 0 Likes
    Paint brushes and rollers can often be wrapped in cling film to prevent the paint from hardening, this is much easier and quicker than cleaning the brush each time.
  • 02:29 Popular How to paint new plaster
    by Admin Added 3,078 Views / 0 Likes
    When painting new plaster it is important to leave the plaster as long as possible to dry before applying the paint. You also need to use the correct paint! It is also a good idea to paint over any angle beading using a suitable primer such as Zinsser 123
  • 06:52 Popular How to paint over render
    by Admin Added 2,110 Views / 0 Likes
    Render walls can be painted with a suitable masonry paint, however it is essential that the render is stabilised first.
