Visit Thermo worx
Tool videos
Tools are as necessary to a man as handbags are to women, you simply cannot have enough tools!
This section shows how to use some basic tools and also describes what some more obscure and less well known tools are used for.
  • 05:53 Popular SDS drills explained
    by Admin Added 1,414 Views / 0 Likes
    SDS drills are the ideal drill for drilling concrete or masonry. These drills come in both corded and cordless versions, with some of the cordless machines having almost the same power as the smaller corded versions. SDS drills are available from 12v cord
  • 04:57 Popular Grinder safety
    Grinder safety
    by Admin Added 1,448 Views / 0 Likes
    Some important safety considerations before using an angle grinder or cut off saw
  • 01:58 Popular Two spanner trick | wrench extender
    by Admin Added 2,047 Views / 0 Likes
    Using two spanners doubled up is not a good idea, a dedicated wrench extender is a much safer option.
  • 06:10 Round bar centre finder | drill the centre of round bar
    by Admin Added 77 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 http://fave.co/2sdV94Q This enables you to find the centre of ant round bar, tube or
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,387 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
    by Admin Added 1,886 Views / 0 Likes
  • 01:58 Popular Angle grinder to shape wood
    by Admin Added 2,253 Views / 0 Likes
    Wood can easily and quickly be shaped with an angle grinder using a flexible sanding pad and abrasive disc. In this video I scallop a piece of wood using this technique. This is also a fast and efficient way of removing excess timber, or rounding off shar
  • 03:41 Strap wrench – a must have tool!
    by Admin Added 79 Views / 0 Likes
    Strap wrenches are incredibly useful tools, the aluminium one in this video can be used on items ranging from about 10mm to 300mm in diameter. Strap wrenches can grip almost anything without damage and so they are useful for anything that has a surface th
  • 05:40 Popular Spirit level tutorial
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 04:12 Popular Cutting steel channel with the Rage 3S
    by Admin Added 532 Views / 0 Likes
    The Evolution Rage 3s 210mm has a maximum metal cutting capacity of 6mm, but in this demonstration I cut through a piece of steel channel that measures 200mm by 100mm and is roughly 10mm thick in places. It’s not recommended to cut such large pieces
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,091 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
  • 02:33 Popular Pipe squeeze off tool
    by Admin Added 1,415 Views / 0 Likes
    Pipe squeeze off tools are used by water and utility companies to squeeze the incoming water supply pipe closed when changing the main stop cock to the property. Smaller versions are also available for squeezing the flexible brake pipes on vehicles when r
  • 03:41 Popular Torque wrench demonstration
    by Admin Added 868 Views / 0 Likes
    How to use a torque wrench to set fasteners to a specific torque setting.
  • 28:01 How to use an angle grinder
    by Admin Added 34 Views / 0 Likes
    This video shows you almost everything you need to know about using an angle grinder. Angle grinders are one of the most versatile power tools that you can get, but they are also potentially dangerous if used incorrectly. For people working in industry in
  • 07:38 Popular How to use a mag base drill
    by Admin Added 699 Views / 0 Likes
    This video shows how to use a mag base drill, or magnetic base drill. Magnetic base drills are widely used in all industrial and construction environments and are one of the most useful drills that you can possibly imagine. Sometimes there is no steel for
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 900 Views / 0 Likes
