DIY videos from Ultimate Handyman
  • 03:02 Popular Energy saving Light bulbs
    by Admin Added 1,703 Views / 0 Likes
    Year on year electricity bills increase at a much higher rate than inflation. By installing low energy light bulbs you can make a substantial saving on your energy bills in a quick time. Typically payback is after 12 months, by that time you have paid for
  • 03:05 Popular How to use holesaws
    How to use holesaws
    by Admin Added 1,674 Views / 1 Likes
    How to use holesaws to cut out large holes from wood, plastic or metal.
  • 01:46 Popular How to free rusted parts | Spray penetrant
    by Admin Added 1,642 Views / 0 Likes
    how to free rusted parts using spray penetrant. Often this is all that is required to free rusted parts.
  • 01:19 Popular Detail sander sheet money saving tip
    by Admin Added 1,628 Views / 0 Likes
    Detail sander sheets are currently £7 for 5 at B&Q but for the same price you can buy a 5 metre roll of abrasive paper, which can be cut to the same shape as the detail sander sheet and can be glued to one of the old worn out sheets, then when t
  • 05:00 Popular How to cut plasterboard
    by Admin Added 1,581 Views / 0 Likes
    How to cut plasterboard/drywall, using the score and snap technique
  • 05:40 Popular Spirit level tutorial
    by Admin Added 1,528 Views / 0 Likes
    A spirit level is very useful when doing a wide variety of DIY projects from wallpapering to installing decking. This video shows how to use a spirit level in normal use and also how to use a level to calculate a fall when installing decking.
  • 03:46 Popular Gyproc Easi-fill | Gyproc Easi filler
    by Admin Added 1,507 Views / 1 Likes
    Gyproc Easi-fill was originally made for filling the joints between sheets of plasterboard or drywall once they had been fixed to the wall using the direct bond method. I know decorators that have been using it as a filler for years and now Gyproc have re
  • 08:18 Popular How to polish brass door furniture
    by Admin Added 1,499 Views / 1 Likes
    How to refurbish brass door furniture, this can save you a lot of money as it is much cheaper than replacement
  • 07:11 Popular How to fix a loose paving step
    by Admin Added 1,491 Views / 0 Likes
    A loose paving step can be a real danger, here we re-fix a loose paving step using a mortar mix of 5 sand to 1 cement by volume
  • 03:14 Popular How to repair Tarmac
    by Admin Added 1,484 Views / 0 Likes
    Damaged patches of Tarmac can easily be repaired inexpensively using a suitable cold lay repair compound.
  • 03:19 Popular How to repair a crack in a wall
    by Admin Added 1,478 Views / 0 Likes
    Cracks can often appear in plastered or drywall walls due to settlement or slight movement. In most cases the cracks are nothing to worry about and are only cosmetic. These cracks in the plaster or cracks in the drywall can easily be fixed using a suitabl
  • 02:57 Popular Remove rust stains from stone or masonry
    by Admin Added 1,467 Views / 0 Likes
    This video shows how to remove rust stains from stone. You can use oxalic acid or Nettrol to remove the rust stain.
  • 03:23 Popular Child proof appliance switches
    by Admin Added 1,394 Views / 0 Likes
    Children just love to press buttons, especially if the button is illuminated. This simple trick shows how to use a small piece of acrylic with a 6mm hole drilled through it to protect the switch from little fingers. The appliance can still be switched on
  • 03:07 Popular Gutter Hedgehog installation
    by Admin Added 1,371 Views / 0 Likes
    The Gutter Hedgehog is a fast and easy way of prevent gutters from being blocked by leaves/debris etc.
  • 02:06 Popular How to change a euro cylinder
    by Admin Added 1,322 Views / 0 Likes
    Euro cylinders are normally pretty easy to change, this video shows how
  • 05:39 Popular How to replace the hose pipe in a Hozelock reel
    by Admin Added 1,271 Views / 0 Likes
    This video shows how to replace a damaged hose pipe in a Hozelock auto reel. The hose pipe in this reel had split in several places and required replacing. The hose length is about 30 metres or £150 feet. This was a bit of a challenge as some of the
