thin crack in wall after lining paper
- Has thanked: 1 time
- Been thanked: 2 times
about a yr and half ago, I had 2 cracks top to bottom of the wall, after stripping, I filled , sanded, and lining papered over, 2 or 3 coats of emulsion, and it looked fine, now ive noticed, down both cracks, top to bottom its opened slightly ?
- 1795605_10200794078613729_934644768_n.jpg (69.75 KiB) Viewed 2691 times
- 1898182_10200794074933637_230148593_n.jpg (51.41 KiB) Viewed 2691 times
- CLOSED ACCOUNT
- Has thanked: 871 times
- Been thanked: 757 times
Re: thin crack in wall after lining paper
Cracks are a law unto themselves. Sometimes you fill them and never see them again and other times they reappear
even if the surface seems really solid.
I would recommend raking out the crack and filling and then using plasterers scrim tape, followed by easy fill before painting.
- wine~o
- Has thanked: 1414 times
- Been thanked: 3992 times
Any other cracks in the building..internal or external ??
If not ...what Fitzy said..
no other cracks, bar next door banging about, so u mean strip lining paper, then rake fill etc then line and paint again, if so will have to wait till next yr now, never noticed it, till lately, wish I never looked, cheers
- CLOSED ACCOUNT
If the lining is well stuck you could leave it on and just treat it as if it is a standard painted surface.hooly wrote:no other cracks, bar next door banging about, so u mean strip lining paper, then rake fill etc then line and paint again, if so will have to wait till next yr now, never noticed it, till lately, wish I never looked, cheers
- Has thanked: 5 times
- Been thanked: 253 times
Rake out the crack without destroying too much of the surrounding paper.
Fill crack level with surface.
Apply Toupret fine scrim
http://www.decoratingdirect.co.uk/viewprod/t/TOUCALFIN/
This stuff gets painted on and is really fine.
When its dry apply a coat of Touprets fine surface filler
http://www.decoratingdirect.co.uk/viewp ... CE_FILLER/
Feather out the edges to blend into your current surface, if necessary fill again feathering out further.
- Has thanked: 379 times
- Been thanked: 584 times
IMO if you are going to use a scrim. I would cut the paper back and then you will blend it in easier.
That toupret scrim is mega fine, it feathers in real easy.
If using a normal scrim then yes I would cut a strip out to bed it in.
- Has thanked: 39 times
- Been thanked: 621 times
Painted lining paper which has a slight textured finish. Cut away paper and fill which will have a smoother finish once painted. Not nice.
Cut the paper back. Sort the crack using one of the above methods.
Then splice a new section of lining paper in and paint. This leaves a uniform finish to the paint texture. It is DIY, you ain't worried about time or cost.
- Morton
- Has thanked: 205 times
- Been thanked: 25 times
I'm with you ROC...I'm not sure you wouldn't see a filled section that had been painted. I think a patch with a very small amount of filler would be my choice.
Well the Toupret fine scrim is just that, mighty fine
It can be only 10% of the thickness of a standard scrim tape, maybe less
Agree with y'all about the repair showing out but unless you re-roll the entire wall the repair will stand out regardless of which repair solution you choose...............................................just sayin.
- Has thanked: 28 times
Good advice, but what do you mean exactly by "Fill crack level with surface"?upagumtree wrote: ↑Sun Mar 02, 2014 9:44 am Rake out the crack without destroying too much of the surrounding paper.
<span class="skimlinks-unlinked">http://www.decoratingdirect.co.uk/viewp ... IN</span>/
<span class="skimlinks-unlinked">http://www.decoratingdirect.co.uk/viewp ... ER</span>/
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 560 times
Zudecke, I've locked this topic, almost all of the above members are no longer active.
