Painting MR MDF
johnstu
Painting MR MDF
Post by johnstu »
Hi, Just enquiring if someone can offer me some thoughts and suggestions? I'm going to be doing some wall panelling using MR MDF and would like to achieve a smooth pristine finish, similar to the pictures below.
I have been advised to have the finished panels sprayed in situ to achieve the best finish. Are they any suggestions of types of paints / methods that should be used to achieve a smooth consistent finish like in the pictures below? Any thoughts would be much appreciated.
thanks, John
Has thanked: 776 times
Been thanked: 3339 times
Painting MR MDF
My link below may help. Aqua satin goes on really smooth but you need to get the sealing coats right.
Argyll
Has thanked: 1169 times
Been thanked: 571 times
Painting MR MDF
Post by Argyll »
There's a guy on YouTube that does this for a living. If you search through his channel you might find a few tips. He's American but that shouldn't make a difference. I think the Americans call it Wainscotting.
https://www.youtube.com/c/FinishCarpentryTV
dynamod
Elephant Man
Has thanked: 589 times
Been thanked: 1430 times
Painting MR MDF
Post by dynamod »
Getting a high quality finish isn't that hard, but correct preparation and technique is essential.
HVLP spray finish is the way to go IMHO. I assume satin finish will be your chosen sheen?
Nihil expectore in omnibus
