Hi all,
First post here. To give you an overview of the situation, I had a room replastered 6 months or so ago. I purchased some silk based contract emulsion from Leyland,that stated it was for plaster.
I found out after that using silk based paint was a no no as the paint does not absorb in the plaster and Matt should have been used.
I debated whether to strip it then but it seemed ok so I proceeded with the final coats. However, after the paint started peeling in massive strips so I have now stripped back to the bare plaster to start again.
I will not be using silk again but my plan is to use some new plaster trade paint for the mist coat, diluted by 10% from the manufacturer. I will then use trade matt paint from dulux for the final coats. I am looking to do one mist coat and 2 final coats.
The walls are slightly dusty so would it be best to use a brush to remove the dust rather than sugar soap?
Some harsh lessons learned so far but I want to make sure I get it right before tackling this again
Many thanks
Paul
Accidentally used silk based paint for mist coat
- Been thanked: 1 time
- Tom d'Angler
- Has thanked: 1131 times
- Been thanked: 549 times
When mist-coating new plaster I always use a standard contract matt rather than anything that specifically says it is for new plaster, so I can't say how the "for new plaster" paints work as a mist coat. For a while I have been using "Wickes Trade Contract Matt Emulsion" and it seems to do the job as expected.Happyhammer7 wrote: ↑Thu Jun 16, 2022 6:33 pm my plan is to use some new plaster trade paint for the mist coat
I'm a big fan of Dulux Trade. Other decorators aren't. I guess it comes down to personal taste and what we get used to using every day.Happyhammer7 wrote: ↑Thu Jun 16, 2022 6:33 pm I will then use trade matt paint from dulux for the final coats.
To remove any dust, I wipe all new plaster with a slightly damp mop, one of those sponge mops that you can wring out quite tightly (Mrs d'A tells me it's called a "butterfly" mop) so it is only just damp and I rinse it regularly in a bucket of water.Happyhammer7 wrote: ↑Thu Jun 16, 2022 6:33 pm The walls are slightly dusty so would it be best to use a brush to remove the dust rather than sugar soap?
That's the best way to learn!
Much appreciated Tom. Its been a journey put it that way.
Nearly finished re-prepping the surface for painting. Whilst most of the silk came off in strips, there were some annoying bits that i had to use a heavy duty scraper for. Had to really take my time with this to avoid gauging the plaster but only a few little nicks, which I will patch up after the mist coat.
Great tip regarding the mop but I ended up using about 10 cleaning cloths, a dust brush and a hoover.
Your idea sounds better though
- These users thanked the author Happyhammer7 for the post:
- Tom d'Angler (Mon Jun 20, 2022 5:17 am)
