I was thinking of making a flower box for my front garden in the shape of the attached diagram.
What I am not sure about is the support needed (show in dark triangular blocks ). How do I go about making them
I am novice at wood work and do not have a lot of wood working tools but thought it would be fun to try and learn in the process.
Does any one have any advice ? or this a project too far ?
I do not want to make a square one ! That would be no fun.
Flower Box
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
Flower Box
assuming they are internal blocks to hold 3 different angled surfaces
unfortunately will be dangerous to make as you are down on the fourth face to perhaps to 40-55mm off fully angled surface with a saw blade angled at least in one direction and no parallel surface to clamp too
fingers and saw blades ideally 75-100mm appart
- big-all
- Pro Carpenter
Flower Box
if they are more Toblerone shaped then you will be ok as its the offcut you use
- Has thanked: 1299 times
- Been thanked: 1175 times
Flower Box
I'd just nail or screw the main box together and then make flat corner pieces out of a piece of board to strengthen it internally if needed.
Don't try to cut small pieces off small pieces though. Have plenty of material to cut the desired piece from.
As B-A says trying to make the shapes as a length on a table saw is dangerous.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2491 times
Flower Box
I don't think there is any danger of that, the OP said
But I was thinking there is one shape that would "fit" a cylinder. It may sound odd, but a cylinder would enable screws to come from any angle and give said screws something to "bite into"
How about 40mm waste pipe? again it may sound odd, but as its a planter, it will get wet, dowel (if you can get it that big) will rot, waste pipe will not rot. Or if not screws, nut and bolt?
- big-all
- Pro Carpenter
Flower Box
we all know best because off the nicks ding near misses and actual accidents we have all hadDave54 wrote: ↑Tue Jun 30, 2020 11:51 am I'd just nail or screw the main box together and then make flat corner pieces out of a piece of board to strengthen it internally if needed.
and we should know better
Flower Box
We don't know what the OP has in the way of tools. I'd assume hand tools, but kit has got cheaper and cheaper.someone-else wrote: ↑Tue Jun 30, 2020 1:23 pmI don't think there is any danger of that, the OP said
Better safe, and it might help somebody else.
I don't have a lot of tools.
Honestly!
Actually using a bit of plastic pipe to strengthen the inside corners could well work. Worth a try I'd say.
And yes, as you say B-A. You always try what you know you shouldn't do at some time.
And then generally remember why you shouldn't do it!
