Metalworking videos
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,368 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
  • 03:01 Popular Choosing a disk for a grinder
    by Admin Added 1,282 Views / 0 Likes
    A look at some of the disks available for fixing to an angle grinder
  • 04:44 Popular Cobalt drill bits
    Cobalt drill bits
    by Admin Added 1,953 Views / 0 Likes
    Cobalt drills are excellent at drilling through hard metals, they can often drill tough metals that a normal High speed steel drill bit cannot drill.
  • 05:42 Popular Cobalt step drill bits
    by Admin Added 340 Views / 0 Likes
    Cobalt step drill bits are normally more expensive than normal step drill bits that are normally made from high speed steel, in this video I test out some cobalt step drills that I purchased from bang good. I order the three step drill set as it was the o
  • 02:41 Popular Cutting hardened steel
    by Admin Added 1,663 Views / 0 Likes
    steel can behardened by having a high carbon content, heat treatment or by work hardening. Cutting hardened steel with any type of saw is almost impossible!
  • 05:41 Popular Cutting holes in metal using a hole saw
    by Admin Added 1,179 Views / 0 Likes
    Cutting holes in metal can be difficult, here we show the correct technique for doing this using a cordless drill with torque control and a good quality hole saw
  • 06:11 Popular Cutting sheet steel using a jigsaw
    by Admin Added 1,459 Views / 0 Likes
    How to cut sheet steel using a jigsaw with a metal cutting blade.
  • 02:41 Popular Cutting steel bar
    Cutting steel bar
    by Admin Added 1,247 Views / 0 Likes
    Cutting steel bar or tube is often difficult unless you have access to a metal cutting band saw. Here we use a Dewalt D28710 metal cutting chop saw to cut a piece of 20mm square steel bar.
  • 04:12 Popular Cutting steel channel with the Rage 3S
    by Admin Added 739 Views / 0 Likes
    The Evolution Rage 3s 210mm has a maximum metal cutting capacity of 6mm, but in this demonstration I cut through a piece of steel channel that measures 200mm by 100mm and is roughly 10mm thick in places. It’s not recommended to cut such large pieces
  • 03:41 Popular Cutting threaded bar
    by Admin Added 947 Views / 0 Likes
    How to cut threaded bar or threaded rod so that it is easy to get the nut onto the bar.
    by Admin Added 1,523 Views / 1 Likes
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,514 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 07:12 Popular drill metal with a  pillar drill
    by Admin Added 2,272 Views / 0 Likes
    drill metal using a pillar drill
  • 02:24 Popular Drill thin metal using stepdrills
    by Admin Added 1,244 Views / 0 Likes
    Step drills are the drill bit of choice for drilling holes in thin sheet metal, these step shaped drill bits make really light work of thin material which is typically difficult to drill using standard HSS drill bits.
  • 03:43 Popular Drilling hardened steel with ARTU drill bits
    by Admin Added 1,685 Views / 1 Likes
    Drilling through hardened steel is now possible using ARTU multipurpose drill bits.
  • 07:12 Popular Drilling metal
    Drilling metal
    Drilling metal is not too difficult as long as you use the correct equipment. Here we showhow to drill steel using a hand drill and HSS drill bit.
