Electrical Videos
In this section you will find videos to help you when doing home electrics.
If you are not 100% certain what you are doing please consult a professional electrician.
  • 09:14 Popular How to install a Wi-Fi extender socket
    by Admin Added 657 Views / 0 Likes
    In this video I replace a standard double switched electrical socket with a British General 922UWR Wi-Fi extender socket, these are a great idea as they allow you to use both socket outlets whilst extending the Wi-Fi network. Visit the British General web
  • 06:32 Popular Wiring a three pin plug
    by Admin Added 1,619 Views / 0 Likes
    How to wire a standard 3 pin plug
  • 03:02 Popular Energy saving Light bulbs
    by Admin Added 1,532 Views / 0 Likes
    Year on year electricity bills increase at a much higher rate than inflation. By installing low energy light bulbs you can make a substantial saving on your energy bills in a quick time. Typically payback is after 12 months, by that time you have paid for
  • 05:19 Popular How to measure amperage
    by Admin Added 1,462 Views / 0 Likes
    How to measure amperage using a multi-meter
  • 07:39 Popular How to install a USB wall socket
    by Admin Added 2,071 Views / 0 Likes
    More and more electrical items can now be charged using a USB lead, which often means plugging an adapter into a standard electrical socket. This can mean that your socket soon becomes busy with items that are trying to use the power outlets. Installing a
  • 11:00 Popular Replacing an electrical socket
    by Admin Added 2,727 Views / 0 Likes
  • 08:39 Popular Replacing a light switch
    by Admin Added 3,040 Views / 0 Likes
    How to replace a light switch
  • 04:35 Popular Wagobox
    Wagobox
    by Admin Added 1,801 Views / 0 Likes
    The wagobox is very handy when joining cables as it can be used in dificult to reach locations as long as wago connectors are used
  • 02:46 Popular In-Line wire connectors- Spliceline
    by Admin Added 2,702 Views / 0 Likes
    SpliceLine™ in-line connectors are one of the easiest ways of joining two wires together without an specialised tools such as crimping pliers. SpliceLine™ In-Line connectors are very compact and are probably theeasiest way of joining two wires
  • 02:06 Popular How to replace a lamp in a downlighter
    by Admin Added 2,358 Views / 0 Likes
    How to replace a downlighter lamp or a halogen lamp in a spotlight.
  • 03:46 Popular how to fit a back box in plasterboard
    by Admin Added 1,685 Views / 0 Likes
    How to fit a dry lining back box in a plasterboard wall.
  • 03:42 Popular Fuse Testing
    Fuse Testing
    by Admin Added 1,412 Views / 0 Likes
    How to check a fuse using a couple of different tools
  • 11:39 Popular How to install a Fused connection unit | FCU
    by Admin Added 3,370 Views / 0 Likes
    This video shows a DIY'er how to install a fused connection unit, often called a FCU. Useful links-http://www.ultimatehandyman.co.uk/routing_a_cable.htm#The latest requirements for running cables is below-http://www.ultimatehandyman.co.uk/forum1/diy-elect
  • 03:10 Popular How to strip electrical twin core and earth cable
    by Admin Added 2,639 Views / 0 Likes
    Twin core and earth cable can easily be striped ready for termination using this method
  • 10:49 Popular How to replace wall lights | fitting uplighters
    by Admin Added 3,358 Views / 0 Likes
    This video shows how to safely replace wall lights and has some good tips on collecting the dust when drilling as well as how to ensure the fixing bracket is completely level.
  • 02:43 Popular Light switch testing
    by Admin Added 2,693 Views / 0 Likes
    This video is useful if you are having problems with a light that either will not switch off or will not switch on (assuming the lamp has been checked).
