  • 01:52 Popular Glass cutting using a glass cutter
    by Admin Added 1,230 Views / 0 Likes
    This video shows how to cut plate glass using a standard glass cutter. You can cut straight or curved lines using a cutter like this, the important thing Is to lubricate the cutting wheel using some oil.
  • 14:40 Popular How to use a mitre saw safely
    by Admin Added 1,189 Views / 0 Likes
    Mitre saws are now very common and can be picked up very inexpensively. It is however very important that these machines are used safely to avoid potential injuries to the mitre saw use. This video looks at using the sliding mitre saw in a safe manner and
  • 00:54 Popular How to cut webbing
    How to cut webbing
    by Admin Added 1,180 Views / 0 Likes
    This video shows how to cut webbing, more importantly it shows how to seal the webbing using a lighter to seal the cut edge to prevent it from fraying.
  • 01:40 Popular Removing staples with the Tacwise pro staple remover
    by Admin Added 1,170 Views / 0 Likes
  • 03:30 Popular Ride on mower wheel replacement
    by Admin Added 1,084 Views / 0 Likes
    Here the back wheel on this Efco lawn mower is removed for puncture repair and then replaced, the wheel is held on using an E clip and washer. It's a good idea to clean the shaft and apply some copper grease before replacing the wheel as this will make it
  • 07:03 Popular Lindam safety gate installation
    by Admin Added 1,075 Views / 0 Likes
    This video shows how to install the Lindam Easy fit safety gate to a landing.
  • 04:40 Popular How to repoint a lead roof valley
    by Admin Added 1,050 Views / 0 Likes
    This video shows how to re-point the lead valley on a tiled roof safely using fibre reinforced mortar.
  • 02:01 Popular How to use bolt cutters | How to use bolt croppers
    by Admin Added 1,042 Views / 0 Likes
    People often damage the cutting edge of their bolt cutters the first time they use them, this is because most people cut through the shackle of the padlock which immediately dulls the cutter blades as the shackle is made from hardened steel.
  • 00:19 Popular halloween prank wheelie bin
    by Admin Added 1,029 Views / 1 Likes
    What can you make using a wheelie bin and some pneumatic controls? Well you could make a prank wheelie bin to scare your neighbours ;-) Special thanks go out to my neighbours Ian and Carole for being such good sports ;-) How to make this prop will be cove
  • 01:15 Popular Measuring pull force using a spring balance
    by Admin Added 1,022 Views / 0 Likes
    It's often useful to know how much force is required to move an object; this can easily be accomplished using a spring balance. Once you know the value in KG’s of the item you are trying to move you can easily convert it to Newtons.
  • 05:33 Popular Safety gloves | Work gloves
    by Admin Added 946 Views / 1 Likes
    Safety gloves are very important when working or carrying out DIY. Each year thousands of people end up in hospital due to injuries that could have been prevented by wearing the correct safety gloves or work gloves. Some of the sites I work on make it man
  • 02:14 Popular Broken double glazed window on the inside
    by Admin Added 937 Views / 0 Likes
    This video briefly shows what can happen to double glazed windows in cold weather once the sun heats the unit up too quickly. The difference in temperature can cause the window to implode, as you can see from the pane of glass on the inside of this double
  • 14:07 Popular Transcend Drivepro 100 dashcam review
    by Admin Added 830 Views / 0 Likes
    In this video the Transcend Drivepro 100 dashcam is reviewed by Mike.
  • 11:24 Popular how to fix squeaky/squeaking/creaking floors/floorboards
    by Admin Added 813 Views / 0 Likes
    how to fix repair squeaky squeaking creaking floors/floorboards. Squeaking floorboards or creaking floorboards are often caused by the boards being loose, the movement that is caused when walking on the boards creates the squeaking or creaking noise. Appa
  • 09:03 Popular How to replace a double glazed unit
    by Admin Added 791 Views / 0 Likes
    This video shows how to replace a double glazed unit in a double glazed UPVC window frame. This window has imploded so the glass is quite badly broken, How this happened is described in this video- https://www.youtube.com/watch?v=I3fGXFRZ3zQ You might be
  • 10:10 Popular how to kill a wasp nest at height
    by Admin Added 612 Views / 0 Likes
    This video shows how to kill a wasp nest which is at height. Killing a wasp nest at height is particularly dangerous and so I made a pole that could deliver the pesticide into the access hole for the wasp nest from a distance. A couple of attempts were ne
