Painting Outside Window Frames - Leaving Windows Open
- Has thanked: 4 times
Hi All,
I'm going to paint my outside window frames and I need some advice about leaving windows open while they dry.
Ideally they would be left open until completely dry, but this is not always possible. For instance, having to leave the house before they've finished drying, or securing the house for the night.
I've been advised to wait until the frames are at least touch dry before closing the windows. If the windows stick, just use gentle taps with the heel of your hand to get the windows open.
It seems to me that this could compromise the integrity of the paint, and reduce how long it lasts before it needs painting again.
Any advice?
Any advice?
- Has thanked: 776 times
- Been thanked: 3339 times
Water-based dries really quickly have a look at exterior water-based paint for windows etc
- Clueless68 (Tue Jul 12, 2022 12:11 pm)
I would have a look at Dulux Weathershield, not at B&Q go to a Dulux Decorating centre https://www.duluxdecoratorcentre.co.uk/ ... ry%2bgloss
- Clueless68 (Tue Jul 12, 2022 1:38 pm)
- Has thanked: 9 times
- Been thanked: 36 times
Zinsser allcoat
- These users thanked the author spottie for the post:
- Clueless68 (Fri Jul 15, 2022 9:27 am)
- dynamod
- Elephant Man
- Has thanked: 589 times
- Been thanked: 1430 times
Putting windows onto their safety catch setting might be an option. Removing rubber seals (if any are in situ) will prevent a tight fit between sash and frame.
All paint needs to cure I'm afraid, and most of these exterior finishes are typically softer and more flexible than their interior counterparts.
Vaseline used sparingly can help, but I'd be very careful it doesn't compromise the surface finish/adhesion.
- These users thanked the author dynamod for the post:
Nihil expectore in omnibus
