Primer for Black Jack
- Has thanked: 26 times
Could anyone please advise a primer to use on outdoor masonry before applying Black Jack. I have had to fill some areas with Toupret masonry filler and on the pack it states not to apply solvent based paints direct to the filler.
- aeromech3
- Has thanked: 177 times
- Been thanked: 652 times
If you must use black jack which will keep moisture out but also lock any moisture in, not allowing masonry to breath then apply a Stabilising Solution first; only an example Everbuild 406 (cheap) and Wicks do one; watch for clear or whitte and of course make sure you choose a water based one.
I hope you used the exterior filler version Touprelith F.
