What is that stuff? If it's of any help I think the house was built in the early 70s. It's quite tough and doesn't crumble. I could find some good uses for it.
What is this "glue" inside wall
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I can only hazard a guess that those boards were at one time dot and dabbed elsewhere and then removed and used where they are now.
That would make the glue either the correct stuff for dot and dab or just some sort of finish plaster, from the colour, my guess there would be Sirapite.
Dot and dab was a fairly new method back in the early 1970s.
- Has thanked: 94 times
- Been thanked: 857 times
its dot and dab aka splat and squidge
those walls are very thin
- ayjay
Doesn't look like it's available now, but google *sirapite plaster* if you want to know a bit more about it.
It's not really a glue/adhesive though, and whatever you want to stick there's probably something better available now.
its common name is plasterboard adhesive it sticks like $%^£ to a blanket
£10 for 25kg or https://www.screwfix.com/p/make-good-mg ... 10kg/230gp or https://www.homebase.co.uk/gyproc-dri-w ... kg_p416584
- Has thanked: 227 times
- Been thanked: 11 times
Thanks Bob, I'll get a bag and give it a try. I think it will come in handy when fixing my screwed up walls.Bob225 wrote: ↑Thu Feb 13, 2020 5:13 pm its common name is plasterboard adhesive it sticks like $%^£ to a blanket
£10 for 25kg or <span class="skimlinks-unlinked">https://www.screwfix.com/p/make-good-mg ... 30gp</span> or <span class="skimlinks-unlinked">https://www.homebase.co.uk/gyproc-dri-w ... 6584</span>
