How strong is steel reinforced epoxy (cold or chemical weld)?
I need to weld a nut to a stainless steel tube but I do not have a welder. I do have something called J-B Weld steel reinforced epoxy which I believe is also known as cold welding or chemical welding. I plan to have a threaded rod go through the tube and screw into the nut, and the rod, tube and nut will be subject to a lot of vibration. I wonder about the strength and durability of using epoxy. The product says it can withstand 5020 psi. Does anyone have experience with chemical welding? How does the bond compare to conventional welding? Do you have any recommendations or another way to securely afix a nut to a tube? Thanks
- Has thanked: 776 times
- Been thanked: 3334 times
I used it to repair a cast aluminum Pressure Relief Valve on my vintage tractor. It was a pinhole that developed and oil squirted out. The repair was fine
I do not know how it will work for you but it must be really clean to get a good bond. I used carburetor cleaner spray.
I think it is worth a try for six quid.
- Has thanked: 100 times
- Been thanked: 1022 times
Use the glue and then drill and cross pin it.
- jaeger
- Has thanked: 40 times
- Been thanked: 76 times
Without a welder I'd also use a rivnut, for a one-off you don't even need the tool, it can be done without.
https://www.youtube.com/watch?v=I6H6wr7fJYo
- Argyll
- Has thanked: 1169 times
- Been thanked: 571 times
You learn something every day. I didn't know what a rivnut was.
- jaeger
Rivnuts are very useful, you can also get them in stainless steel ( a bit harder to install) if OP wants to keep all the materials the same.
UHM Also has his own video (I forgot about this)
https://www.youtube.com/watch?v=f7yIqKnLGPc
- Has thanked: 94 times
- Been thanked: 858 times
If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
- Has thanked: 77 times
- Been thanked: 335 times
FLow drilling and tapping is a handy process for manufcturing...
https://www.youtube.com/watch?v=7YSVClLMp60
- jaeger
I first saw Cleco being used on 'A plane is born' I used to enjoy that series of 'A XXX is born'Bob225 wrote: ↑Fri Jan 31, 2020 4:50 pm If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
Wasn't that a Louis Theroux documentary
The cleco clamps are very good too
- jaeger
Last year at a car boot, I saw a box full of them but no insert tool, should have bought them but I just passed them by
