makita charger question
- Been thanked: 1 time
bought an oldish 18v drill which hadn't been used so as new ,two batterys both good the red bottom ones ,anyway all ok did a full decking in the summer no probs,then goes to charge up the batterys few days ago charger dead no light on nothing ,so managed to buy another , the both batterys are flat , but when I put them in the other charger the light went from red to green in two minutes ,green saying 100% surely a flat battery would take a while to charge up ,swapped in the other one and it did the same red to green in a couple of mins
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
and oldish nicad or nmh battery will loose perhaps 15% capacity per year so after about 5 years can be fairly useless
what make and capacity [amp hours]are you batteries ??
- Has thanked: 1299 times
- Been thanked: 1175 times
Difficult to know what's wrong without having a known good battery to test the charger.
Is the charger new or second hand? Is it exactly the same type as the old one?
It's all going to depend on how the charger works as well. It could be "seeing" a battery that will take no further charge current as being fully charged.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
You can buy a converter that allows your drill to run on the new lion batteries. I bought one for my old DeWalt and works great.
ok thanks ,the batterys are ok just thought it odd they charged up so fast my 14.4 dewalt when flat takes a good half hour maybe longer ,ive checked the charger and its exactly the same
- Has thanked: 32 times
- Been thanked: 788 times
usually when the batteries are past their best they take less time to charge up. a new battery normally takes about a hour in my experience. i had a drill a while back that the batteries started to charge up fully in 2 minutes or so..... then they would be flat after a screw or 2....
currently i have dewalt xr tools and about 12 or so batteries. the original 2 charge up in about 5 minutes and are next to useless so they are on a shelf in my garage.... need to drop em off somewhere to get propperly recycled rather than jus hoy em in a skip. the other older batteries are now noticeably dropping off so i think soon ill have to either buy a new tool with batteries or a few batteries from the dewalt shop down at spennymoor
yes fin your right although they felt strong after literally I min of charging just done a bit of drilling and it died quite quickly , so what ill do now is try it for say half an hour and see what they are like then , as I said in my first post the kit is old but had never been used ,and they worked fine on the decking job in the summer then the charger died ,but got another now so fingers crossed it puts in a decent charge
- Argyll
Fin do you get good deals down in Spenny?fin wrote: ↑Mon Jan 13, 2020 7:24 pm usually when the batteries are past their best they take less time to charge up. a new battery normally takes about a hour in my experience. i had a drill a while back that the batteries started to charge up fully in 2 minutes or so..... then they would be flat after a screw or 2....
- big-all
- Pro Carpenter
little used can cause failure quicker than in use daily as crystals form in the batteries causing greater self discharge
fortunately lion batteries do not suffer from long periods off non use
ermmm it depends at spennymoor. its not massively cheaper than if ya shop about online. maybe £10 or £20 cheaper. theres loads of package deals but again it depends whats there. sometimes ya can pick up decent second hand batteries for say £20 each which are obviously from tools returned under warranty that are fecked. take the batteries out to sell on as seen and bin the rest. or like i once got a couple of new ones for maybe £30 a piece. but theres all sorts there ya jus gotta ask. one of my mates went and spent like £3 or £4k and they gave him shed loads of stuff he just asked. he got like free tool boxes and levels and saw blades and all kinds of other stuff.
pretty sure i got my table saw for about £40 or £50 cheaper than i could find it anywhere. and same for my mate with his thicknesser. all of the stuff has factory rework stamped into it. though wether that means that they were broken or if they are maybe seconds or whatever i dunno. theyve not caused me any problems though
