Stud finder
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Stud finder
They're all a waste of time.
Studs are usually at the same centres across a wall, generally @ 400 or 600mm in a newer build or 16" in an older one.
First check any skirtings for signs of fixings, a good chippy will mark the studs on the floor before fixing the skirtings and the studs will be vertically above the fixings. If the skirtings were glued on this probably wont work.
Tapping with the blunt end of a pencil is also a pretty good way of finding them, it sounds more solid over the stud.
Once you've found one, it shouldn't be too hard to find the others.
If you're fixing something like a batten along a wall, don't be frightened to poke holes in the wall behind where the batten will be until you find them.
- These users thanked the author ayjay for the post:
- Job and Knock (Fri Jan 03, 2020 6:01 pm)
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Stud finder
Tried a few of them including megabuck "professional" models, but yet to find one that works consistently, especially on older buildings with lath and plaster stud walling. As AyJay says, look for signs of fixings in the skirtings (e.g. filled nail holes which may be a slight depression viewed in an oblique light). You can sometimes measure out from the corner of a room, too, then poke a few small holes with a sharp awl to confirm. Another way is to get a rare earth magnet and move it slowly back and forth across a suspected stud position - the strong magnetic attraction of the magnet to steel plasterboard screws (modern fixing), clout nails (older plasterboard fixing) or even the tacks used to affix timber (lath and plaster walls) is often a useful aid
- Has thanked: 283 times
- Been thanked: 397 times
Stud finder
I’ve got a set of these https://www.first4magnets.com/circular- ... pull-p6418 and they are very good and easy to store in the toolbox.
Mike
Mike
- Has thanked: 775 times
- Been thanked: 3316 times
Stud finder
No mate, but occasionally all the odd screws in there form a almighty mess when the get stuck togetherdewaltdisney wrote: ↑Fri Jan 03, 2020 6:44 pm Does your toolbox stick to the side of the van Mike
Mike
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Stud finder
I bought an expensive Bosch one a few years ago. After turning a plasterboard wall into a pin cushion I returned it a few days later. Neodymium magnets all the way.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Stud finder
The owner of this website made a good video Click here
