Hi guys,
I have come across a single light switch for my bathroom which connects to the bathroom light and the extractor fan. The light switch has 5 live wires going into just two terminals. There are 3 brown going into the L1 terminal and 2 wires (one brown and the other black with a brown sleeve) going into the common terminal. I want to separate the light and fan into a double switch, can this be done with just the wires in the current switch. There are 4 cables feeding into the light box and a terminal block with 4 neutral and 4 earth wires connected to it.
Thanks in advance...
Combined extractor fan and light switch connection problem.
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
almost certainly yes...
lecky off then disconnect and isolate the 2 wires that are currently in com. (by isolate I mean put them in a piece of connector block not connected to each other) restore
electric. If I'm reading your post correctly then neither the fan nor the light should work.
Report back.
Report back.
Hi Wine~o
Thanks for the reply but I want to change the single light switch to a double so I can operate the fan and the light separately.
Cheers.
Cheers.
- wine~o
I know . I was trying to establish which were the switched lives for A) the fan and B)the lights. reread my post.
