Copying photo from Doro phone to pc
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Which actual phone model may become a necessary question.
With a smart phone, you should be able to email it to your pc and then download it from there.
I'm sure that there are other ways to do it involving google drive (or something similar) with an android phone, but emailing works fine for me.
- Has thanked: 775 times
- Been thanked: 3311 times
If it is an Android phone then click on the picture you want and some symbols will appear at the bottom. Click on the three balls joined by lines which is the share button. Select your email host from the presented menu and type in your own mail address and send the picture to you inbox. Go to your email and lift the photo from there. You can also send it from Google back up.
Sound long winded but it isn't
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2486 times
There is also blue tooth.
The other way is to connect the phone to your PC by cable, and do it that way (its quicker too) Depending on phone it may ask if the PC has permission to connect to the phone, obviously you say yes. Mine does that and until you say yes on the phone, you can't see anything of the phone from the PC
