Top hat spacers for a plastic cover
- Has thanked: 94 times
- Been thanked: 858 times
Ah it's the pull start cover it's the collar to stop you crushing the plastic
Edit. It's the GGP WBE0701 engine best bet is to find a used pull start
You should be able to pop one of the others out, measure it up and post them on this thread, and I will see what I can do
- Has thanked: 8 times
- Been thanked: 2 times
Widest collar is 14.5mm
External OD of insert is 10mm
ID of insert is 6.6mm
Total length is 10mm
- Pull_Start_Cover_Insert 001.JPG (82.87 KiB) Viewed 3428 times
- Has thanked: 1299 times
- Been thanked: 1175 times
Bodger Dave thinks
"Get a bolt the right diameter. Cut to length. Drill hole down centre (do-able with a hand drill with careful marking out and care to keep it square) file the head to thickness."
Its all in hand, its a tad warm in the workshop today plus it give me an excuse to go out it the jungle - sorry garden
PM me your address and i will stick it in the post tue/wed, you may need to open up the internal dia or fettle it a little
