Lidl Thursday 18 July.
- Has thanked: 855 times
- Been thanked: 994 times
The usual DIY stuff at Lidl. What catches my eye is the wet and dry vacuum and only because it has a power take up socket. Potentially good for dust extraction.
- Has thanked: 100 times
- Been thanked: 1022 times
I have had a couple of the Lidl vacs with PTO, very handy for sanding, routing and the track saw.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
I'm looking at the core welder. What would be the advantages/disadvantages over the Parkside stick welder?
- Been thanked: 1 time
The big Lidl/Parkside shop vac is pretty good based on my 2 year experience with it. It's a bit noisy but works well and is very convenient with power tools.
Don't quote me, I played a lot with old heaps (cars) by necessity but never did any welding. Is it similar (the same?) as MIG welding which needs to be done in a garage or similar so there is no wind to upset the whatever gas? The sticks get too hot so they are of little use if you are using them on thin metal as you get a hole where you try to weld?
You made me look it up, but I have not read it yet https://en.wikipedia.org/wiki/Flux-cored_arc_welding.
