Fitting a new security light
I have a wall with wires coming out of it which looks like the image here:
These wires are connected to a switch on the other side.
There are 2 brown wires, 2 blue wires, and one earth wire.
I want to connect a security light to these wires.
What kind of security light would I need to buy in order for it to be compatible with these wires?
I know from the previous installation that the 2 brown wires terminated in one plastic block left to do nothing.
So does that affect the kind of light I buy or should I connect the brown wires somewhere in the new light?
Appreciate the help,
JH
JH
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
It is up to whoever wired it what colour does what, so there is no definitive answer, however, could you clarify..........
1) Are you saying the previous light was only connected to the two blue wires?
2) Was the previous light "just a light" with an on / off switch say in the house?
3) Just saying, there are actually TWO earth wires in the same sleeving, but we will not worry about those at this time
Yes, the previous light was only connected with the 2 blue wires and the earth wire. The brown wires were both inserted inside a plastic termination piece.someone-else wrote: ↑Thu Jul 11, 2019 8:28 am It is up to whoever wired it what colour does what, so there is no definitive answer, however, could you clarify..........
The previous light was also a PIR security light, but I still had the ability to switch the whole thing off with a switch on the other side of the wall.
Since it was wired in this way (with the 2 brown wires just terminating in a plastic box), do I HAVE TO do the same for any new light I buy?
If so, is there a particular connection type I should be looking for on the new light?
JH
- Someone-Else
Yes, if you want it to work the same way the previous light did.Jetheat wrote:(with the 2 brown wires just terminating in a plastic box), do I HAVE TO do the same for any new light I buy?
You will not know what you will be getting until you have paid for the light and have it in your hands. Most manufacturers will save money where they can and one way is to use the smallest cheapest connectors they can. Which you the try and replace with better quality ones, and find out there is no space for the new connectors and all the cables, enter the weatherproof junction box.Jetheat wrote:If so, is there a particular connection type I should be looking for on the new light?
- Someone-Else
You connect it the same way the one you had was connected.
As for if you can do it in the one you have shown a picture of, who knows? (The picture is too small, the picture does not show how much room between the connector block and the edge, you / we will never know unless you try
I get that part because I understand I need to fit the plastic termination block in there for the brown wires. But what about the 2 blue wires I have. Will that suit the connection that's on this light?someone-else wrote: ↑Thu Jul 11, 2019 10:05 pm You connect it the same way the one you had was connected.
Coz I have 2 blue wires and it looks like just one connection for blue wires on the white plastic in this light.
JH
- Approved Electrician
- Has thanked: 223 times
- Been thanked: 657 times
One of the blue wires is the switched live, the other blue is the neutral. It's always going to be tight when there are two twin and earths at the fitting.
You should manage in the first fitting as that has quite a bit of space in it (
I have fitted them)
I have fitted them)
- Someone-Else
Try it and see.
It should be the switched live that goes into the live connection on the light fitting (although it will almost certainly work either way). You do need some test gear to find out which is the switched live and which one is the neutral. The switched live should have had brown sleeving on it to show that it is a live and not the neutral and should have been put there by the person that installed the first light and that is not your fault. To do the job correctly you would need simple test equipment such as a cheap multi meter.
- Someone-Else
What OnlyMe says is true, but this is a DIY forum, people believe that there is a "way" of knowing what wire does what if they post a picture of said wires, they don't need a multimeter thingy since if they ask they will get the answer they want.OnlyMe wrote: To do the job correctly you would need simple test equipment such as a cheap multi meter.
It's not really that simple, and just because "it works" does not mean it is safe, I advocate that before anyone considers any electrical work they buy and learn how to use a multimeter, do they "listen"?
