Mystery tool
- jaeger
- Has thanked: 40 times
- Been thanked: 76 times
Mystery tool
Found this at a car boot, seller said it was something to do with door hanging, looks like that's in the right area, Anyone know?
- 2019-07-04 10.56.19 (Medium).jpg (166.63 KiB) Viewed 3498 times
- 2019-07-04 10.56.28 (Medium).jpg (172.27 KiB) Viewed 3498 times
- 2019-07-04 10.56.32 (Medium).jpg (129.2 KiB) Viewed 3498 times
- 2019-07-04 10.56.39 (Medium).jpg (165.69 KiB) Viewed 3498 times
- jaeger
Mystery tool
Seem to have found it, but no idea how to use it
https://www.drywall-emporium.com/multi ... 85-p.asp
- Has thanked: 1299 times
- Been thanked: 1175 times
Mystery tool
Turn it over, put the short end under the door, step on the long end. . .
I've got something similar I made out of wood years ago.
- Has thanked: 94 times
- Been thanked: 857 times
Mystery tool
3 and 4" are common hinge sizes, it can be used as wedge or lifting device (a old chisel on top of a hammer does the same job)
I will have a looksee on YT
here you go, same principle (not slipped once with a hammer and chisel method )
- Has thanked: 100 times
- Been thanked: 1022 times
Mystery tool
I use a bit of dowel on my flat bar, free and doesn't take up much room in the tool bag.
Mystery tool
Last time I hung a door I did the same. Only IIRC I used the flat bar with a screwdriver handle.
I've got a proper tool I made, I didn't say I knew where it was!
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Mystery tool
Don't know how I ever managed without one.
A wedge or a flat bar, (or usually both) for me.
Not so much for hanging doors, but if you're doing a lot of doors and have to fit the architraves as well, I made up a little jig for marking them out. Two overlapping triangles of ply, overlap one by 8mm and just run it round the liner and make a few pencil marks to work to later - BEFORE YOU HANG THE DOOR.
I did consider putting a metal edge at the tips of the triangle to clean the plaster snots off of the door liner as you run it round, but never actually bothered.
Mystery tool
I've got a few of those, going to try them next time I fit a door, not something I do very much which is good cos I am not great at it! lol.
The airbags are really handy though, I use them to lift up things like washing machines to get wheels under them.
Mystery tool
Yes, I've got a couple of those little airbags. Handy for all sorts. Nice thing about them is you can get the position of whatever you're doing spot on.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
