Hi all, just signed up and after a little advice. Above my front door and window there’s a canopy with wood on it. It wasn’t in the best shape when I moved in, weathered and flaky. I’ve cleaned it up, sanded it down and filled and holes or gaps and re sanded down.
I then used ronseal outdoor wood paint, big mistake... stuffs like mucky water, 6 coats and it’s not any better, tonight I’ve added a coat of Cuprinol after good recommendations. Both pints water based.
I didn’t use any primer or undercoat, beginning to wish I did.
What’s the best way to sort this out? Will more cots get rid of the filler marks or shall I use primer, any advice is good advice!
Hopefully the pictures work, the paint is a grey colour.
Outdoor wood painting, can’t cover filler?!
- 3545CE53-24BB-4386-B2CB-2F4255FE8FDB.jpeg (297.05 KiB) Viewed 1145 times
- 58C18042-96D0-4F2A-B5C9-9896E8FA6A20.jpeg (323.95 KiB) Viewed 1145 times
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
no expert here
i think what you have used is shed or fence type treatment where you dont seal the wood but may or may not give it protection but not from water
as an aside i have used ducksback on my now 15 year old shed [workshop ]and its waxy and 100% seals and keeps moisture out with 2 or 3 coats every say 4 to 5years
- Has thanked: 139 times
- Been thanked: 113 times
You filled and sanded to bear wood and painted without primer, have you read the instructions if they require primer? Are they outdoor paints?
I have painted wooden garage door some 10 years ago, sanded filled primed and then dulux weather shield exterior paint. Still there but about time to re do it.
- Has thanked: 855 times
- Been thanked: 994 times
1. Can you find on the Ronseal website the paint you used or post a photo of the container? Is it here? https://www.ronseal.com/for-home/doors- ... ood-paint/
2. Did you mix the paint really well as in spend minutes mixing it and not 10 seconds? Often, the solids sink to the bottom of the tin.
3. As Ronseal and Cuprinol belong to the same company, I think Cuprinol tends to make paints for fences and sheds so you maybe screwing things up by not sticking to what you started with.
EDIT. 4. How long did you leave between coats?
