Dumb DIY novice question - fixing to plasterboard
Hello! So, I am completely new to any form of DIY, and I've just bought a house with my partner but it turns out he's even more clueless than me
We have lots of things that need to go on the walls, and I want to learn how to do it because it seems ridiculous to pay someone to do something so (apparently?) simple.
My first task is to hang a bar/rack of 5 coat hooks (all on one structure, 60cm wide). I am assuming a plasterboard wall as it sounds hollow, and I think I can detect some studs from knocking on it. I was planning to use the neodymium (?) magnet method to find the studs. However, I read that the studs should be 60cm apart? The mounts for the fixings on this particular piece are 35cm apart - does that mean I can't fix it to the wall? Does it depend on the weight (which will obviously vary depending on what we hang on it!)? Which would be the best fixings to get?
I am so sorry for the stupid questions, but I really want to learn! This will teach me for choosing a useless boyfriend, haha...
Really appreciate any help
Naomi
Naomi
- Has thanked: 775 times
- Been thanked: 3311 times
Re: Dumb DIY novice question - fixing to plasterboard
You really have to ascertain the wall structure as this will decide the choice of fixings you use. In a new house it is possible that some walls are dry-lined which is where the plasterboard is dot and dab fitted to a constructional wall as a cover. Next is stud walls which are normal for room partitions. However, you do also find in modern houses a sandwich like partition wall made of two sheets of plasterboard with an egg box type centre. It is very hard to detect which is which and the fixings you use can be different to suit the wall. Is there anyone to check with who might know, is there still builders on site or could you telephone to ask?
- Has thanked: 283 times
- Been thanked: 397 times
Assuming you can locate the studs using the magnets and assuming that the wall studs are wood, you could make your own coat rack up to the exact size you want and put the screw holes so they line up with the studs.
To make the coat rack, buy a piece of planed square edge board ( wickes etc ) 19mm thick x 100mm wide, cut to length and paint, add hooks of your choice and drill holes for screws in the wood so that you can screw it into the wooden upright studs.
If you live in a new property, the studs will probably be metal and they have a channel in them to accommodate wires or pipes and may not be so easy to fix to without damaging a wire or pipe in the process.
Mike
Mike
- Has thanked: 32 times
- Been thanked: 786 times
for fixing stuff to plasterboard walls these things are mint
https://www.toolstation.com/gripit-plas ... str=gripit
i use them fairly regularly. ive hung anything from tv's to coat rack's to kitchen cabinets on these
ohh and obv that kit i linked has a variety of different sizes so they carry different weights. all ya need is a cordless drill and the right sized flat bit to go with them
yea aslong as there is a bit of clearence behind itll be fine. actually fixed a tv in the pub i go to anto what ended up being a plywood partition. i assumed it was plasterboard but it was 2 sheets of what seemed to be 1/8th ply.
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
I'm just trying to figure out why, if you have ply, a very good patress material which will allow screwing directly iinto it, you'd ever need to use a Gripit. Not keen on them myself. The demo on Dragon's den where the inventor fixed a radiator to a wall using Gripits which promptly fell of didn't instill much confidence in me, either
Thanks for the responses. I am really not very confident in determining what the wall structure is, so I will try to get the builders next door to pop in and have a look! A few other people have recommended the Gripit fixings as well, so I will check those out.
Cheers,
Naomi
Cheers,
Naomi
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Gripits aren't bad to be fair in the right circumstances. I've used them a couple of times. If you're wall is double boarded you'll need this tool:
https://www.gripitfixings.co.uk/collect ... tting-tool
I had to buy one last month.
If you have a Home Bargains near you they sell Gripits cheap as chips.
In your situation I would attach a second piece of longer dressed wood to the coat rack and fix to both studs either side. Coat racks take a lot of abuse and I suspect gripits would look good at first but through time I think they'd fail.
- aeromech3
- Has thanked: 177 times
- Been thanked: 649 times
Hi, just some thin ply boarding in a concrete garage that I wanted to attach to.Job and Knock wrote:I'm just trying to figure out why, if you have ply,
- Job and Knock
Assuming that it has enough screws to fix the plywood to the walls of the garage and that it's at least 1/4in (6mm) thick, then just screw to it. If you need to carry a lot of weight it's probably worth gluing and pinning a patress (plywood, MDF, chipboard, blockboard, 2 x 1 softwood, etc) onto it just to spread the load over a bigger areaaeromech3 wrote:Hi, just some thin ply boarding in a concrete garage that I wanted to attach to.Job and Knock wrote:I'm just trying to figure out why, if you have ply,
j&k when i put the tv up in the pub the wall was of unknown construction. i could see tiles through the hole i drilled. the ply was only 1/8th so i didnt wanna risk the screws pulling out and the tv falling off the wall. that would be an even bigger disaster than newcastle getting beat.
plus with it being a pub that was last propperly done out probably some time in the 70's or maybe early 80's i didnt want to run the risk of disturbing anything dodgy like asbestos that may have been hidden.
those grip its are actually pretty decent. ive had one or 2 not work propperly but ive still used a canny few and they do help out on occasions. if i was building the stud work myself id cover myself for thigs like hanging radiators or whatever so id not need them.
