I put one of these push pneumatic type delay switches in a garage for an outside light, so as you left the garage you had light for a short while
But two now have broken, you can nolonger push the button in - both did the same thing after about a year or so
The switch is inside a large backdoor on the garage - not sealed but does not let any water in
and reasonably shettled spot, although it can get windy and we are about 0.5km from the sea.
I purchased 1 from screwfix and I think the 2nd one from CEF
this sort of thing
https://www.screwfix.com/p/elkay-columb ... itch/68088
Any alternatives that will work inside a garage by the sea ?
the alternatives, I have seen requires a neutral - which we don't have - although i maybe able to do something about that
Delay light Switch in Garage by the sea
- Has thanked: 94 times
- Been thanked: 857 times
Re: Delay light Switch in Garage by the sea
If your having issues with ingress (more than likely salt in the air) go IP rated you should be able to get a enclosure for the switch
The other way you could do it is a standard switch and a timer
https://www.timeguard.com/products/ligh ... lay-switch
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
not sure about the ingress, but was only the reason I could see for it getting to stiff to push in.
i guess i'll have to see where I can pickup a neutral from or means rerunning a long length of 3 core
Simple DIYer
Wayne
Wayne
- Has thanked: 775 times
- Been thanked: 3315 times
I use a PIR light bulb which costs a couple of quid. As soon as you approach it comes on and it stays lit for about three minutes. You can get screw and bayonet. Works a treat in my porch. See https://cpc.farnell.com/tcp/160slmsa10e ... 26%20Tubes
- etaf
Not quite going to work, as I wanted it to be ON before we come out of the garage as its round the side and so although lights up the paths - motion detection wont be seen until we are around the corner and then the worst bit is over
BUT i will change to that for my porch , i was going to replace the light fitting, but not seen anything we liked as much as the old fitting we have - so that would work a treat there - Thanks
Oh, OK hadn't thought of that - thanksIt may be heat cycling related, garages do get ice cold
Simple DIYer
Wayne
Wayne
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
That can cause a lot of problems with RCD's.etaf wrote:i guess i'll have to see where I can pickup a neutral from or means rerunning a long length of 3 core
Better off installing a 3 core and Earth such as this
