Which mini down lights?
- Puma
- Has thanked: 681 times
- Been thanked: 704 times
I am looking to put mini downlights in my shower room. I have found some here but they are Miniature Adjustable LED Downlight 3W Ansell Iris at about £15 each. Is this about as cheap as they get?
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Re: Which mini down lights?
SELV? IP rating ?? what zone are you installing in ? (if applicable)
- bath_zones_2011.jpg (77.02 KiB) Viewed 2337 times
- Has thanked: 94 times
- Been thanked: 857 times
They need to be ip rated, what size are the ones your looking at, 35mm ??
£15 isn't than expensive - does that include the driver/transformer or are they 240v ?
Aurora do some nice fittings
https://auroralighting.com/gb/
- Approved Electrician
- Has thanked: 223 times
- Been thanked: 657 times
wine~o wrote:SELV? IP rating ?? what zone are you installing in ? (if applicable)
That picture has the obligatory joke zone 2 around the sink
- wine~o
Don't blame me, I didn't install the sink...OnlyMe wrote:wine~o wrote:SELV? IP rating ?? what zone are you installing in ? (if applicable)
A quick Google suggests that the Ansell lights the OP is looking at are built in LED 12V non IP rated lights. The trouble with them is that if one fails in 3 years time then the OP might not be able to find a replacement.Bob225 wrote:They need to be ip rated, what size are the ones your looking at, 35mm ??
I would suggest lights where you can swap the lamps.
And BTW Aurora are about the best
- Puma
Sorry for the delay Wino and all. Last evening I was sat in a pub garden to celebrate the sunshine, and today we went to Slimbridge Wetland Centre basically for more sunshine - a pretty nice place that was too.
They will all be ceiling lights in a wet room / shower room. I over looked the lack of the Ip65 rating on the ones I was looking at. I will have a look at the Aurora line. I just want anything smaller than usual really.
Is it a full wet room ? iirc it has to be IPX4, if its a shower IP65 (technically ip44 should be ok if above 2.25m)
what is the ceiling height ?
A quick look - Aurora Enlite E5 - IP65 - around the £12-15 mark
https://enlitelighting.com/gb/productdetail/en-de5
