New pc.............
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: New pc.............
I still can't mount the SSD There was nothing in the bag apart from cable ties and lots of small screws and some "funny" sponge washer / spacers.
I have given up for today, other things still to be done.
But the good news is it has an SSD with windows XP working on it, and it has sound (had to install the driver separately) It cant connect to the www (But it never will in its "normal job") I did activate win XP on the phone and they said to keep the code as it will work again.
The down side is the programme I built the PC for will not work, it has a dll missing, and even though I pasted one in there, it still says its missing
I have lots of boxes to shift now. (Which is what I was supposed to be doing)
- Someone-Else
All is working. I did say I would post a picture.........
In summary I wanted a desktop P.C. with a solid state hard drive that runs windows XP.
It had to be XP as the programme I have runs on XP or 98 and sadly the writer of the programme (Friend of mine) passed away 2 years ago, as I know that a rotating HD will fail at some point I wanted to keep the software working for years to come, hence the SSD
Several places I asked / looked at said it can't be done / needs an emulator.
Well it can, its quite easy (I even used an old copy of XP that I re-registered) but it does take time, I am now very happy that I should be able to run the programme for many years yet to come.
(The programme is a "sophisticated timer")
This was the main ATX power cable after I had to extend it.
- Someone-Else
Bob225 wrote:your ssd will mount to the back of the motherboard tray with 4 screws
It might well supposed to do that, but it won't.
I watched a video of Carry Holzman installing one, the one he had slid straight in and stayed there, I slid the one I have in, and it fell down. Either the bays are too wide or the "tray" I have is too small.
I have also seen them mounted "on the wall" of the case, my "holder" does not have screw holes for this method.
- Someone-Else
Back to the zip clips it is. Onto the next job of the day.
- Has thanked: 94 times
- Been thanked: 857 times
it should mount to the tray no issue hold it in place insert screw through hole and repeat as required,
what case model is it ?
you have the orange plastic ssd frame, tuck one side of the ssd in it bent the other side of the frame and clip it on that slides into the 3.5 bay
- Someone-Else
The SSD mounts to the tray no problem, its mounting the tray that is the problem. Don't worry about it (But thanks) Once mounted the only access I have is to the sides of the tray, but I can's as the power supply is in the way one side and the front cover on the other. (Yes, I know the front cover pulls off, still can't get to the other side)
