Trying to replace euro cylinder lock on upvc juliet balcony doors as we were given no keys from previous owners.
Have taken off handles and can see no securing screw within the frame.
any thoughts ! have viewed you tube vidoes which all appear to show securing screw being removed
renew euro cylinder lock on upvc juliet balcony doors
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: renew euro cylinder lock on upvc juliet balcony doors
The securing screw is often underneath the faceplate of the lock, (on the leading edge of the door) however, you'll struggle without a key as that is usually required to turn the lock snib into the correct position to withdraw the cylinder.
- Has thanked: 283 times
- Been thanked: 397 times
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
As ayjay says, removing the cylinder without the key will be errr.... problematic.London mike 61 wrote:This video made by the owner of this site may help
https://youtu.be/2lzX5sSTbig
Mike
- Has thanked: 94 times
- Been thanked: 857 times
3 options, pick the lock, Drill the lock (cobalt or better drill bit), or if you have enough cylinder hanging out - just snap it
All the above is assuming its not a high security cylinder
I'm not going to post any links but vids can be found on youtube/google on the above methods
A picture of the offending lock may be useful
