Currently I have a Shower over the bath but an elderly relative can not use it. So in order to accommodate them I believe I can tack a shower onto the downstairs toilet area.
I believe there is currently room between the end of the toilet room and the doorway into the kitchen (see pics)
I had a plumber around who told me I need to have a raised shower tray because the pipe work can’t go under the floor(the current pipe work is boxed in).
He quoted me £850 for tiling, fitting shower, shower try and new small wash basin_ - does that seem reasonable?
He told me I need to buy all the stuff tiles, shower, shower tray, small basin, bi-folding doors.
He also told me he doesn’t do walls so I would have to get area built up first n that it didn’t need planning permission.
So I got to wondering should I just do this myself?!
The wall at the end of the toilet room seems to be solid so that would have to be removed and a frame created. The water pipes should be easy to run to the shower since there is already hot n cold running to the sink.
I don’t want the shower area to feel really confined so I was wondering about using a 900x900 sower tray.
He said bi-folding door but I saw some sliding doors in Homebase the other day would’t they do just as well ?
I am a competent DIYer so I was wondering what you guys thought ? Any tips ?
Any recommendations for good a Raised Shower Trays, Thermostatic Shower, shower doors ?
Addition Of Shower Area To Downstairs Toilet Room
- Has thanked: 87 times
- Been thanked: 3 times
- Outside wall and door to the toilet room
- 3959A879-EFE6-4302-91FB-ED79B1E45A59.jpeg (28.54 KiB) Viewed 1401 times
- End Wall of toilet room n area to be used to extend room - shower area
- 1D6199EE-EA39-4CF4-98EF-DFDDCA355111.jpeg (28.69 KiB) Viewed 1401 times
- Current basin and end wall of toilet room
- 0324F41A-AEEB-4AB6-834D-658706AF0025.jpeg (18.2 KiB) Viewed 1401 times
- You can see current pipe work boxed in on the floor to the left
- 7AFB5B2F-1053-4312-A8DE-B12182C8BCED.jpeg (25.23 KiB) Viewed 1401 times
Power to the little people
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
Re: Addition Of Shower Area To Downstairs Toilet Room
whats the pressure like on the hotwater ?
I assume the hot tank is in the loft and 2 floors - so should be fine or a shower , if it works upstairs already.
22mm or 15mm hotwater to downstairs ?
OR are you having a Electric shower?
I'm in a bungalow and just in the middle of doing the showers - one off the hotewater, so making sure enough pressure to run was critical.
wheres the sink empty ? - can the shower waste run in the existing boxing and get the required fall
Toilet fowl pipe ?
Toilet fowl pipe ?
The combi boiler is in the utility room which is where the toilet room is. So the boiler is on the other side of the room so only a few feet away from where the shower will be. Although the pipe go upstairs n come down to the toilet room. The plumber put in the boiler n saw no issue putting in a thermostatic shower in (that’s what he recommended). 15mm in toilet room.etaf wrote:whats the pressure like on the hotwater ?
Toilet fowl pipe ?
Yes the waste can be run into the pipes already boxes in.
