Making the cord length on a light pendant longer
- Duck_Tape
- Has thanked: 151 times
- Been thanked: 45 times
Hi everyone
I have a property with a high ceiling. There are existing light pendants with a long cord but they are old, discoloured and tatty. I would like to replace them with some new pendants
I initially bought these items from screwfix
this cable 2 core 1.5mm which in the comments someone said they used it for the same purpose I intended.
and these Pendants with the view, to remove the existing cable from these new pendants and use the newly bought cable to lengthen the pendant
(i.e. remove the existing cable from new pendants giving a separate ceiling rose and bulb holder and then use the new cable cut to the correct size to reconnect the ceiling rose and bulb holder creating a new longer light pendant.
Problem is the cable will not fit through the hole on the ceiling rose or the top of the bulb holder. It goes in about 1.5mm but that’s it.
Question: What is the correct cable I need to buy to get the cable to pass snuggly but easily through the ceiling rose and bulb holder, or what pre made pendant will have a slightly larger hole for the cable to pass through.
Duck Tape
Duck Tape
I love hard work, I could watch it all day
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: Making the cord length on a light pendant longer
You don't need 1.5mm flex for a pendant.
You can use 1mm or 1.5mm T & E to supply the lights / ceiling rose, (Perhaps that is where you got the 1.5mm from?)
But the flex from the rose to the pendant lamp holder is usually 0.75mm twin. Example
- Has thanked: 94 times
- Been thanked: 857 times
0.75mm 2 core round is all you need, I spent the best part of a week making up roses (many moons ago) some of them with 3m drops (klik style roses)
the cable through the rose doesn't need to be snug as the cable is secured and goes around the roses strain relief hooks (some also come with a cable clip)
- Duck_Tape
I am still on this
Bob225, 0.75 2 core round
I need to know more, like where to buy.
CEF ???
Thanks Duck Tape
I am still on this
CEF ???
Thanks Duck Tape
- Someone-Else
I always found CEF to be expensive.
You can get it from all the usual suspects it's your choice. e.g. Toolstation, Screwfix, TLC direct, local electrical wholesaler, DIY shop, DIY superstore
It doesn't have to be round you can get oval too.
Failing that Click here
someone-else wrote:You don't need 1.5mm flex for a pendant.
- Duck_Tape
Off the top of my head, 2192Y
Don't know how these things stick in my head (use to work in a wholesalers)
- Duck_Tape
Thanks Folks
I was hoping for an exact match in diameter for the cable removed from the pre-made pendants
I found it online (Code 3182Y) at least I think I have, some retailers sell the item as(1.0mm² 3182Y 2 Core Flexible PVC cable, White )
Screwy Fix has it as this(3182Y 2-CORE 1.5MM² X 10M WHITE
So one is 1mm and the other 1.5mm
Its annoying that the codes cannot be consistent.
I hate paying postage from an online retailer where the postage cost is far in excess of the product cost so I will go with this from screwy fix
As suggested by someone-else
Lets call this closed
Cheers
Duck Tape
Cheers
Duck Tape
screwfix strike again, This link is for oval cable
My fault (fat arthritic fingers) - typo on my part - 2182Y
https://www.toolstation.com/doncaster-c ... 82y/p51676
