Help sourcing these screws
- Has thanked: 2 times
Hi all,
Am wondering if you can help me - I was fiddling with a light fitting we recently purchased and undid the small screw at the base of the fitting which takes the weight of the fitting when hung. Predictably, I then dropped the screw & it's nowhere to be found (and the fitting shipped without spares)...
I've attached some images here - as you can see it's a tiny screw (about 5mm long and the same diameter). I've no idea at all where to get some replacements and am wondering if you can help me...
- IMG_20190201_103556-600x800.jpg (81.61 KiB) Viewed 2547 times
- IMG_20190201_103535-600x800.jpg (131.65 KiB) Viewed 2547 times
- IMG_20190201_103605-01-600x801.jpeg (85.22 KiB) Viewed 2547 times
- Has thanked: 10 times
- Been thanked: 194 times
Re: Help sourcing these screws
Looks like some form of “grub” screw around M6 thread. A grub screw with a hex socket would no doubt do the job.
Look up ur local fastener suppliers, they will most likely just give you a grub screw FOC or penny,s
- Has thanked: 1299 times
- Been thanked: 1175 times
It's called a grub screw. Possibly M5 or M6 5 or 6 mm long
You'll probably find that the ones available are hex drive for an allen key.
Either Ebay, or a local engineer's supply place.
Take the existing one with you.
You can, at a pinch, cut a slot across the end of a bolt, and then cut a piece of thread off the end of the bolt to suit.
Beaten by Chippo1!
Beaten by Chippo1!
- Has thanked: 99 times
- Been thanked: 1022 times
Is it metal, sometimes those screws with that design of head are plastic.
Good point! That design of slot was scratching in my head somehow.Rorschach wrote:Is it metal, sometimes those screws with that design of head are plastic.
- Has thanked: 94 times
- Been thanked: 857 times
A close up you can see the sprue mark in the middle of the thread more than likely a nylon grub screw, If its a cheap Chinese light fitting it could be a imperial threadRorschach wrote:Is it metal, sometimes those screws with that design of head are plastic.
Hi all! It is plastic as you say. Thanks for the responses - from what you're saying it sounds as though I need to go somewhere a bit more specialist than Screwfix?
- Has thanked: 775 times
- Been thanked: 3311 times
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
No idea where to get a replacement, when I have dropped small items like that I find the best way to find them is to lay on the floor and get your eye as close as possible to the floor and have a good look... surprising what you can find...
Good idea that. Same sort of principle, get a small bright torch and shine it across the floor as low down as possible.wine~o wrote:No idea where to get a replacement, when I have dropped small items like that I find the best way to find them is to lay on the floor and get your eye as close as possible to the floor and have a good look... surprising what you can find...
Picks it out with the light and it throws a shadow as well.
Getting back up off the floor is the problem and the interdimensional worm hole that eats everythingwine~o wrote:No idea where to get a replacement, when I have dropped small items like that I find the best way to find them is to lay on the floor and get your eye as close as possible to the floor and have a good look... surprising what you can find...
- wine~o
Have you started celebrating my Birthday before I have ?Bob225 wrote: and the interdimensional worm hole that eats everything
