First time posting on the forums, any help appreciated.
I moved into a house last year with an electric front door that requires a radio key to unlock it (a bit like a hotel room). No problems setting it up but now the battery needs replaced, and that needs a special spanner. I've managed to work out it's a CES Omega Flex lock and tried contacting CES (a German company) but no reply.
Does anyone know where I can get these spanners, or even where I can get these locks so I can try and track down a replacement spanner?
I've attached a photo of the lock and the picture of the spanner.
Thanks, Danny.
Changing the battery on an electric door
- Has thanked: 100 times
- Been thanked: 1022 times
Re: Changing the battery on an electric door
Are you insured for that lock with your house insurance? I remember reading about how easy they are to crack.
Might be better off just replacing the lock
- Has thanked: 61 times
- Been thanked: 319 times
If you decide you still need one Have you tried address below ?
https://www.ces.eu/en
Uk division
CES Security Solutions Ltd.
Unit 4 Kendon Business Park Maritime Close
Medway City Estate Rochester, Kent Me24JF
England
Customer Care Manager UK
Natalie Hatton
natalie.hatton@ces.eu
Tel no
+44 1634 713 369
+44 1634 786 833
Uk division
England
Natalie Hatton
Tel no
+44 1634 713 369
+44 1634 786 833
- Has thanked: 94 times
- Been thanked: 857 times
Is it single sided ? if so it will be easier to remove it from the door, im sure you could open it up with a pair of circlip pliers once off
tbh I would replace it with a high security dimple key euro, unless access I required by a 3rd party
Thanks for the replies.
An update - the company CES have got back to me. The spanner I need is only made in Germany. It costs £7 plus £19 shipping! It's a specialised part as it's external facing so can't be too easily tampered with (the rest of the lock can be removed with a screwdriver and hex key). I think I will go for that and curse the former owner for not having a normal front door.
Its a standard door, it CAN use a standard/high security euro cylinder for around 20 quid you just need to work out the size
https://www.handlestore.com/blog/measur ... ck-barrel/
eg.
https://www.ebay.co.uk/itm/YALE-Superio ... 0005.m1851
https://www.ebay.co.uk/itm/Avocet-ABS-H ... :rk:2:pf:0
eg.
