Replastering old plaster.
- Has thanked: 7 times
Just started enjoying plastering. My question is why can I not plaster directly only old plastered walls. Walls brushed clean. I have skimmed with multifinish and it seems ok. Do I have to prep with 50/50 PVA each time and why?
John
John
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Re: Replastering old plaster.
The main reason not to is that skirtings/architraves will look odd, light switches and sockets may also need longer screws fitting..
As to the 50/50 Pva/water, 1 part Pva to 4 or 5 parts water is the norm, the pva is there to control suction/ stop the plaster drying out too quickly.
- wine~o
If you do you'll need to do it again the next day, apply the Pva, leave until it's gone "tacky" then crack on.
Hi, I am plastering small areas at a time at the moment. Want to do 1/2 a wall at a time. How do I join up the plaster sections to give a clean smooth finish? Any ideas,
John
John
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
Fit a 3mm thin coat stop bead ( the wrong way round ) so you can plaster to it then remove when drying leaving a clean edge to skim to.
- These users thanked the author cotswold builders for the post:
- 27188
- wine~o
Not ideal. put a batten up about halfway along the wall. plaster up to it. Remove batten once dry.27188 wrote:Hi, I am plastering small areas at a time at the moment. Want to do 1/2 a wall at a time. How do I join up the plaster sections to give a clean smooth finish? Any ideas,
John
Plaster other side but dampen where the join will be... You'll probably need to sand along the join to get a better finish.
EDIT or what Cotswold said.
wine~o wrote:Not ideal. put a batten up about halfway along the wall. plaster up to it. Remove batten once dry.27188 wrote:Hi, I am plastering small areas at a time at the moment. Want to do 1/2 a wall at a time. How do I join up the plaster sections to give a clean smooth finish? Any ideas,
John
3mm batten helps get the layer of plaster correct depth, good
- Has thanked: 283 times
- Been thanked: 397 times
If you are going to do half a wall at a time then ( as long as the first half is hard from the day before ) after removing the stop bead , you should be able to blend the two together by giving the join a rub over wth a sponge float and a light flick over with a wet paint brush.
Depending on how you get on, you may only need to use the paint brush which essentially turns the plaster into a wet mix and is easier to feather out.
I’m NOT a plasterer just diy but this is the best way I have found to blend two surfaces together.
Mik
Mik
- 27188
- Has thanked: 32 times
- Been thanked: 788 times
ya could always put a line of scrim on the wall. then plaster just past it. then when its jus starting to set after youve flattened it off pull the scrim off leaving a straight edge. obv youd have to scrape off whatever plaster went past the scrim.
