In my bedroom I have 2 switches that are wired into the lighting circuit. They are wired as follows: 2 reds into the top terminal, 1 red into the bottom terminal, 3 blacks linked together and not connected and 3 earths linked together and fixed to the metal back box. 1 red, 1 black and 1 earth are from a short length of 3-core that sticks out of the wall to accept a light fitting fixture.
I would like to change the switch faceplate to a switched 3-pin socket faceplate so that I can plug in a light and do away with the extra wire altogether.
Is this feasible?
If so which wires should I remove and what alternative connections from the wires list above do I connect to the 3-pinsocket faceplate live, neutral and earth sockets?
Electrical wiring question
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: Electrical wiring question
It is more trouble than it is worth, you would also probably have to change the back box for a deeper one, and the switch on the socket would only turn on or off the socket. Better off ignoring the switch and plug what ever new light you have into a normal socket.
