I am wanting to fill some holes and re drill them.
It will need to be able to take the weight of a tv bracket and tv, what would you suggest using, what is the strongest stuff to use?
Filling holes suitable for re drilling
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Filling holes suitable for re drilling
Simplest option is to drill larger holes for a larger fixing.
What material are you drilling into - and do you expect to make a new hole in the filler?
- Has thanked: 94 times
- Been thanked: 857 times
If its into stone fill them with resin, imho the filler will not hold once drilled out
eg. https://www.screwfix.com/p/fischer-fip- ... 00ml/23386
