Hi guys
Apologies if I'm in the wrong thread but I thought this was the most appropriate one.
I'm looking to wall mount a 49 inch LG TV onto a plasterboard and stud wall. The TV weighs approximately 13kg. I've located the studs and I'm fairly comfortable with the measurement and installation process.
As with previous installations I plan to use coach screws to attach the bracket to the wall. The brother in law and I had a chat regarding what size and length of coach screw to use. I was thinking M6 screws at 50mm length. My brother in law is going with M8 with a length of at least 60mm.
Can anyone offer pros/cons on the above suggestions or recommend anything else and their reasons.
Thanks for taking the time to read this and for any input.
Coach screw length
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
Re: Coach screw length
bracket/washer thickness then 50mm -60mm into the wall assuming into wooden stud
- Has thanked: 32 times
- Been thanked: 786 times
if ya cant hit the studs with the bracket then grip it fixings are decent. they do one thats rated to take the weight of tv's drill a hole into the board and push the grip it in. follow the instructions. super easy
