Need some help! Horstmann Economy 7 Quartz
Rhaom
Has thanked: 1 time
Post by Rhaom »
I have just moved into a property that has a Horstmann Economy 7 Quartz and I have no hot water.
Looking at the dial on the meter it does not seem like it should be complex but I do not understand at all how to set the timer.
The instructions state:
The 24 Hour dial rotates once each day. It should be set so that the time line is against the ‘WINTER
TIME’ line in Winter or the ‘SUMMER TIME’ line during British Summer Time.
I dont understand what "the time line" is.. There is no indicator so how do I know which way to twist it so that it lines up (with what???) or what time it is currently reading :wtf:
aeromech3
Has thanked: 177 times
Been thanked: 648 times
Re: Need some help! Horstmann Economy 7 Quartz
Post by aeromech3 »
:welcomeuhm: Turn the black dial to align the actual time of day with the Winter Time mark (your picture is showing it as time of day 16:45). Then when you have the water heater white switch to on the power will be applied during the off peak period.
wine~o
Has thanked: 1413 times
Been thanked: 3991 times
Post by wine~o »
:welcomeuhm:
Pic 3 was taken at 16.40 (i downloaded it and checked the exif data) so the time is set correctly give or take a few minutes.
A few things that need checking.
1) are you actually on an economy seven tariff ? You can normally tell from either your consumer unit or your electricity meter
(depending on the meter you will have one or two buttons to press, first press will show daytime units used, 2nd press nighttime units)
2) do you actually have voltage at the lower of the 2 immersion heaters (Remove plastic cap and check with a multi-meter (black lead from the meter to negative then the red to positive, fingers well away from any bare metal) NOTE there will only be voltage present when switched to E7 if you are indeed on E7
I notice in one of the pics that "Boost" is on, Boost is normally connected to the upper immersion heater. There is no cable running to that immersion... If it turns out that you have had E7 meter removed in the past then boost may be normal to heat the water.
Immersion thermostat should be set to 55 C approx (black cover off and check, also check if a reset button is present, some have them, some don't)
Finally for now, the immersion element itself could have failed. In which case the cylinder needs draining and the element and thermostat replacing.
moderator2
UHM Super Moderator
Has thanked: 154 times
Been thanked: 560 times
Post by moderator2 »
Sorry Someone-else. It's both an Electrical and plumbing question. Staying here for now.
Rhaom
Has thanked: 1 time
Post by Rhaom »
wine~o wrote::welcomeuhm:
Thank you for the response, but I'm not really sure of the answers to your questions, I moved into this property 48 hours ago, I spoke with the landlord and he has told me that the system was newly fitted as the whole property has just been renovated so I am assuming I must be on an E7 tarrif? :dunno:
When I moved in I was getting no water at all when I tried to run my hot taps, this was due to the valve that supplies hot water being shut, I have since opened that and I now get water, its just cold but I have a concern that there is now evidence of a leak at the bottom of the boiler (shown in the pictures below).
The boost mode was on cause my landlord told me to try doing that, which I did for an hour and there is still no hot water which would make sense as you are saying there is no cable running to it!
Also I dont have a multi-meter at hand to test question 2). I will have to do that after work tomorrow
Electric Meter
Electric Meter
Leak - Dunno if i should be concerned (the system is newly installed)
Top thermostat
Top thermostat
Bottom thermostat
Bottom thermostat
wine~o
Post by wine~o »
Right. zoomed in as much as I could on the bottom immersion, seems to be set to about 40 C... needs to be 50/55
It's up to your landlord to ensure that A) you have hot water etc. and B) that you know how to use it.
As for that leak. that doesn't look too clever.
Looks like you have 2 issues, one with electrics. one with plumbing.
Make that 3 issues... 3rd issue is a landlord that also doesn't care.
exif 2.jpg (270.44 KiB) Viewed 7429 times
Switch that white switch to off-peak overnight.. do you have hot/warm water in the morning ?
Rhaom
Has thanked: 1 time
Post by Rhaom »
I do not believe I am on an E7 tariff, as according to a quick google, if I had an E7 tarrif my MPAN number would start with 02 and mine starts with 14.
(https://www.uswitch.com/gas-electricity ... economy-7/)
The switch was set to off peak last night and I still had no hot water when I got up this morning.
As I said in the previous post my landlord told me the system was newly installed when the house was renovated which is clearly not true!
I have turned the water valve back to shut for the time being due to the leak and I will call my landlord again tomorrow!
Thank you for your assistance :)
wine~o
Post by wine~o »
Tell him about the leak that should get is arris in gear...
Rhaom
OnlyMe
Approved Electrician
Has thanked: 223 times
Been thanked: 657 times
Post by OnlyMe »
Rhaom wrote:I do not believe I am on an E7 tariff, as according to a quick google, if I had an E7 tarrif my MPAN number would start with 02 and mine starts with 14.
That looks like an economy 7 set up.
The meter has a sticker on it saying 2 rate. Where do the two wire from the meter that go downwards lead to?
ericmark
Has thanked: 113 times
Been thanked: 774 times
Post by ericmark »
With the old system the top immersion heater is used with boost so it only heats top of tank at a lower temperature, and bottom heater used over night, so likely boost will not work as top immersion not wired up. There was an instruction to link terminals 4 and 5 when single immersion used, that may have been done.
There is a clear test label with date, I would not say 10 years plus is new.
Since hot water was turned off when you moved in, there is a chance that the immersion was burn out because of no water, but it's down to land lord to sort, not you.
Return to “Electric Forum UK”
