Hi
I have some internal thresholds that require some TLC.
What paint could i use if i decide to paint them white. Do i need primer etc. I currently use Crown Fastflow Satin waterbased.
Could anyone recommend an alternative.
Gary
Internal thresholds
- Has thanked: 855 times
- Been thanked: 994 times
Re: Internal thresholds
What are they covered/painted with now?
Painting them white does not sound sensible to me nor do I have any idea for paint that is going to be durable enough not to mark/scrape and look bad after a short time.
I would leave them as that (refresh them if you like). You want any wear not to be as visible. I would not paint tham in any colour that far from the actual colour of the wood.
The alternative is to replace them e.g. Stainless steel thresholds (there are different profiles and widths but this is the firt company google gave me).
PS. If you must paint them I will make some suggestions but how they will last I do not know.
Yes, keep them as wood.
Sand them back is certainly step 1. If there is varnish on them (you may tell by previous stains) you would have to varnish again. Clear is one option, varnish in colour another. Go easy if you choose colour as you can make them darker but it is not easy at all to make them lighter if you do not like them.
If you had new wood or wood that did not have anything put on it previously I would suggest a floor oil. Under the circumstances varnish is your best option. I would recommend 1 litre (???) of Liberon https://www.liberon.co.uk/product/natural-finish-floor-varnish-2/ but I am sure you will find some Ronseal stuff if you visit B&Q or similar. You will need 2-3 coats and the more coats the shinnier they will get (for a short while anyway). With water based varnishes/paints, paint quickly and move on, do not overbrush or go back to it to touch it up. Some Ronseal stuff (real quick dry) I used on my only wooden threshold was drying on me before I finished.
If it helps a little
- Has thanked: 279 times
- Been thanked: 327 times
