Is this car speaker knackered?
- Has thanked: 159 times
- Been thanked: 17 times
Hi all
Unfortunately I don't have the means to test it at the moment.... Just wondered if anyone can tell me by looking whether this speaker is dead or still usable?
Cheers
Cheers
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: Is this car speaker knackered?
As you said without testing it there is no way you can tell if it is any use or not, although it does look like it has seen better days.
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
to be fair if you used double sided tape and re stuck it down any distortion is likely to be similar to the resonance when attached to a door card or parcel shelve
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
No. Unless the voice coil is open circuit (meter test for continuity required) but if it 'makes sound' then it's ok - although hi-fi purists would call me a luddite.
- Someone-Else
He can't. He already saidBob225 wrote:check the both the VC's with a meter
udaman wrote:Unfortunately I don't have the means to test it at the moment....
- Has thanked: 10 times
- Been thanked: 194 times
Across the connections dab a supply from a normal AA battery it’s only 1.5 volts certainly the bass section you will see move and the tweeter will make a sound ! If you have no meter just a dab.
