How do I store a worktop jig?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
I have a new Howdens worktop jig. I've had it stored behind my sofa as I'm wary of leaving it in my shed as I thought it may warp but then I thought it should be okay as it's laminated.
How do you store yours?
- Has thanked: 248 times
- Been thanked: 208 times
Re: How do I store a worktop jig?
Mine's in the garage in it's box
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Like a cane fishing rod - hung against a flat wall in an atmosphere not prone to wild changes of temperature & humidity, so not a shed. Definitely not on a shelf.
If laminated, what's it made of? I thought worktop jigs were 8mm or 10mm aluminium.
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Mine's behinf=d the sofa in a carrying bag. Made from 8mm thicj=k HPL
The only ones I've seen ;like that were made by Titman. Expensive and rare. Festool do a sectional aluminium one as well - even more expensivearco_iris wrote:If laminated, what's it made of? I thought worktop jigs were 8mm or 10mm aluminium.
- Has thanked: 775 times
- Been thanked: 3314 times
- Has thanked: 94 times
- Been thanked: 857 times
A velvet lined box
Is it a phenolic resin type jig
eg. https://www.axminster.co.uk/ujk-technol ... jig-508615
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Same here finfin wrote:in my garage with other stuff or in my van. no box or bag. its alreet too not warped or nowt
