Light switch only works when one is on.
- Has thanked: 6 times
Hi all, .
One light switch (bottom of stairs) needs to remain on for the other (top of stairs) to work, if bottom of stairs light switch is off top of stairs switch does not work.
1 light fitting (chained recessed lights) 2 switches.
Light fitting is connected up by taking a feed from another light into a JB, the JB then has the light fittings all chained up with a typical light switch setup to ONE switch. The one switch does not have any wire going to the second light switch and i cannot see or find out how the second switch is connected up or interacts with the upstairs light fitting.
Any ideas how this voodoo might work?
All other lights in house work fine when the downstairs light switch is off.
Bottom light switch is 2 gang 2 way with 3 cables (t+e). Worse case would be to rewire the hallway which i am avoiding as i would also channel out the light switches as i am fairly sure the wires are plastered in without any protection.
- Has thanked: 1299 times
- Been thanked: 1175 times
- Has thanked: 248 times
- Been thanked: 208 times
Re: Light switch only works when one is on.
It'll be incorrectly wired. Look up 2 way lighting. 4 cores are required to allow correct functionality.
Dave54 beat me to it.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
has it always been like this or what has been done recently?
Thanks Dave, yes i know how to wire a 2 way switch you can also wire it via one switch power and the other switch to light fitting but the light switches do not connect to one another and i cannot seem to find out how it connects to the light fitting.Dave54 wrote:Any help?
http://www.ultimatehandyman.co.uk/video ... 9bece.html
I am sure of upstairs wiring as they had two switches to control the recessed lights upstairs, i removed one switch and chained the lights together so only one switch is required. I do not think the previous owners knew how to add extra recessed lights to the chain and instead installed a new light fitting and switch.
It is as i said feed from a JB into the light fitting and then a switch off it. How this downstairs light interacts with upstairs is beyond me and all other light fittings in house work fine.
It has always been wired like this apart from (me fixing the recessed light chain upstairs which i posted before).someone-else wrote:has it always been like this or what has been done recently?
The ONLY thing i have added is a fibaro dimmer module to the hallway (which works perfectly fine). but excluding this module, i do not see how this light switch connects to the light fitting or switch upstairs. This makes disconnecting or rewiring it that extra hard work
So if you can't fathom it and you've seen it how are we supposed to work it out blind? [emoji23]
I was hoping that someone had some ideas of weird wiring they have come across that might explain this voodoo.Ktuludays wrote:So if you can't fathom it and you've seen it how are we supposed to work it out blind? [emoji23]
What are the chances of COM, L2 being wrong way around that might cause this?
So to put the question another way, did the 2 way switching work properly before your modifications, or has it always been faulty?SquirrelHammer wrote:It has always been wired like this apart from (me fixing the recessed light chain upstairs which i posted before).someone-else wrote:has it always been like this or what has been done recently?
yes it worked fine before. I also don't see how taking a switch and recess light of can break it. if I remove upstairs switch the downstairs switch can happily turn lights off and on. no idea how it even connects to the light fitting
This may be stating the obvious, but something you've done has broken it. There's no real "standard" way to wire these things, and one wire looks like another. Label the wires before removing them.SquirrelHammer wrote:yes it worked fine before. I also don't see how taking a switch and recess light of can break it. if I remove upstairs switch the downstairs switch can happily turn lights off and on. no idea how it even connects to the light fitting
As for how to fix it, it's not easy to do from a description, but start where you made the modifications.
- Someone-Else
Before what?SquirrelHammer wrote:yes it worked fine before.
well I reset it all back and no idea how this downstairs light links up to the landing so going to wait for wife and baby to go out and channel out the wall. gives me a chance to add extra switch and lights too.
I will just have to stick a wago or something on the end of the wires behind the switch as no idea where these are coming from. I know disconnecting them makes no difference to any lights.
I will prob end up rewiring the downstairs at this rate as I hate it how sparkys save wire by taking power from light switch rather than a jb.
- Someone-Else
The norm is NOT to take power from a light switch since most light switches are just live and switched live.
To use JB's is not good either since apart from the fact they must be accessible they are another "joint waiting to fail"
The idea is there are as few joints as possible.
Upstairs is fine I replaced all the ceiling roses with JB attached to joists, I can easily take a feed from upstairs to down as I am wiring a second switch from the landing. The downstairs is a mess, feeds are taken from light switches and there is a borrowed neutral from upstairs lighting so potential for feedback. Since I will be working on downstairs light switch for landing I might as well look at the hallway. I could easily take a feed from upstairs and JB it off but since I am looking at hallway I can hopefully figure it out and put a jb in. I need to do some tests on the wires and tracing as I need to make sure that the borrowed neutral lights are on the same breaker.someone-else wrote:The norm is NOT to take power from a light switch since most light switches are just live and switched live.
While doing so i might end up removing the wago connectors as i will know where the feed is coming from
The biggest issue is the mess from wall chasing and doing it when the wife is in a good mood
I replaced my ceiling rose upstairs with jb attached to joists in accessible locations. If this is not a good idea what other options are there? The idea was that i could then installer nicer light fittings than a pendant and i removed all the choc blocks wrapped in tape or covered in expanding foam.
