what angle for fence post points?
- Has thanked: 39 times
- Been thanked: 3 times
I want to put a couple of small posts in the ground but what angle do I need to cut the post at, to make a spike?
Not for a fence but to put a sign onto
45 degrees is too blunt
thank you glassescase
- Has thanked: 248 times
- Been thanked: 208 times
Re: what angle for fence post points?
About 75 or there abouts should be ok?glassescase wrote:I want to put a couple of small posts in the ground but what angle do I need to cut the post at, to make a spike?
What size posts are they. You can buy spikes for 3 x 3 posts
- Has thanked: 775 times
- Been thanked: 3314 times
Do you mean a point? It depends what tool you have as a sliding saw makes this easy. If you are doing it with a hand saw then mark the centre on one side and draw lines out to the sides at an angle that looks okay. Cut a point shape and then do the other (now sloped side) in a similar way. It does not have to be precise, if it has a nice point is all you want. The angle will vary depending on the width of the post.
Make sure you treat the cut end too as exposed fresh cut wood will rot quicker
thank you for the advice.
posts are only about 40mm square. Hopefully I will only need them for a few weeks. They will just have a small sign on them and I'm hoping to put them 6 inches into the ground.
I have a compound mitre saw but it only does up to 50 or so degrees. I'll cut a bit of wood at 45 degrees, butt up to that then only need 30ish degrees from the saw
glassscase
glassscase
- Has thanked: 199 times
- Been thanked: 482 times
Been cutting a few stakes myself recently. I tend to cut a wedge off around three times the width of the stake. Repeat four times and there's your point. I commonly just use an axe but I have done the last lot with a mitre saw. I just left the saw at 0 and held the stake in my left hand at the correct angle. It doesn't really matter if the angle isn't perfect , soon as it hits a stone it's likely to be buggered to a degree .
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
That's exactly what I do. Sliding mitre saw - I make stakes out of 2x2, typically to support swmbo's runner bean wigwams. Too much hard work to do it by hand saw (or axe) but then it helps to have the machine. Twenty quid at a car boot sale if you're lucky.Grendel wrote:I have done the last lot with a mitre saw. I just left the saw at 0 and held the stake in my left hand at the correct angle. It doesn't really matter if the angle isn't perfect , soon as it hits a stone it's likely to be buggered to a degree .
