Acceptable tolerances for window frames
- Has thanked: 1 time
I've recently had new timber windows fitted to a listed building. On the plans submitted for Listed Building Consent, the frames are listed as 50mm wide. What tolerance is acceptable based on the premise that the design is for those to be 50mm?
- Has thanked: 775 times
- Been thanked: 3314 times
Re: Acceptable tolerances for window frames
I would have thought that as a listed building these pedant planners should have specified imperial measurements not metric. You have an argument if they get silly that you were copying the original dimensions in inches
- smokey5877
It is only partly an issue with how the Council view it. I agreed the width to be 50mm, what would Joiners be happy with as a tolerance to be a "good job"? It is softwood and made in the workshop, not on site.dewaltdisney wrote:I would have thought that as a listed building these pedant planners should have specified imperial measurements not metric. You have an argument if they get silly that you were copying the original dimensions in inches
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
It really depends on how it's worded. A normal view of a 50mm timber dimension on a drawing is that this is a nominal measurement and the finished size will be about 44/45mm, but if it says 50mm FS then it should be 50mm - FS = finished size.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Falkirk building standards state -0mm/+2mm
I'm not sure what the regs are elsewhere.
thanks all.
I've measured my window and the frame width is 56-57 mm when it should be 50mm. I just wanted to know if the fitter is blagging when he says 57 mm is within joiners tolerance. I see NHBC regs are much tighter, and the figure I seem to be getting back is 5mm tolerance maximum. The window is only 900 mm x 900 mm so I'd have thought things would be more accurate.
- ayjay
They've probably used the nearest stock size that they had available - at a guess, a nominal 2.5" which when prepared will come down to 2.25" or 56/57mm.
Seems very odd, as the same people did 5 other windows in the summer all 50mm or there abouts.
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Are the people from the listed building consent office happy with it ?? If so not a problem...
