Placing joists onto wall with acute angle
So I'm putting some joists onto a wall plate but they are 8inch and the roof pitch means they won't get on the wall plate without me cutting them from the top, at an angle(i've provided an illustration as to how it would look). I'm just wondering will building control accept this? wouldn't it weaken the joists? Would be open to any suggestions thank you!
- Joist_illustration.png (5.57 KiB) Viewed 1658 times
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Placing joists onto wall with acute angle
I've encountered this problem before and I'm not sure if there is a definitive answer.
I've done it, and the rafter returned to its full depth less than two inches away from the plate. This was accepted by Building Control but I don't know if we'd have got away with much more.
It's probably best that you discuss it with your building inspector.
- Has thanked: 200 times
- Been thanked: 482 times
In most cases where I have encountered this I've flown the joists over the outside edge of the wallplate andcut them off in line with the tops of the rafters then fixed everything together.
