Can i get a template to make 1930s pattern in concrete?
- Has thanked: 1 time
- Been thanked: 3 times
Can anyone please advise whether it is possible to get a template (or whatever the word is) to imprint a pattern on to concrete?
I am patching damaged concrete in a 1930s driveway and there is an imprinted pattern I would like to match.
Photo attached to show the pattern.
The indentations are approx 2cm apart (centre to centre)
Would be grateful for any advice as to where I can obtain this.
Many thanks
Brissle
Many thanks
Brissle
- Concrete pattern 4.jpg (268.28 KiB) Viewed 2437 times
- Has thanked: 199 times
- Been thanked: 482 times
Re: Can i get a template to make 1930s pattern in concrete?
To be honest it looks a little irregular and out of square so I very much doubt it was commercially made . You'd probably be as well as having a go and make one , perhaps a piece off ply with what looks like quite thick studs or nails should do the job.
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
- Rating: 35.71%
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Nice one Ayjay. I never knew such a beast existed.
- Has thanked: 1299 times
- Been thanked: 1175 times
Likewise. Seen that pattern lots of times, but never thought about how it's made.
- ayjay
I was fairly sure that such a thing existed, and the irregularity of the pattern more or less suggested it too, Mr Google did the rest.wine~o wrote:Nice one Ayjay. I never knew such a beast existed.
Thanks everyone - problem solved - I shall make up a suitable block with nails as suggested - I Googled the device and it costs £175 to buy it -- OTT for a one-off job.
I knew someone would know. It's all to do with knowing what to Google........
thanks guys
Brissle
thanks guys
Brissle
- Has thanked: 775 times
- Been thanked: 3314 times
Use flooring brads as the heads will give the squarish hole pattern
- ayjay
Those big square headed nails used for corrugated roofing might be just what's needed.dewaltdisney wrote:Use flooring brads as the heads will give the squarish hole pattern
I realise this is a long delayed response - found all recent notifications were being dumped in Spam for some unaccountable reason.
Any way the problem solved itself - a local tool hire company in Bristol had the machine that ayjay told us about and a day's rental did the trick.
great result - thanks again, everyone.
