No newel posts
Watchnlearn
Been thanked: 1 time
No newel posts
Post by Watchnlearn »
I currently have a built in stair rail balustrade (appears to be plasterboard over stud timber work with a wooden hand rail finishing the top of the plasterboard. I was hoping to convert it to an open spindle balustrade instead. I've already opened up a small 4 inch section where I was hoping to see a newel post. However, there appears to be a 2x2 timber, so I presume there are no newel posts and the balustrade is simply a 2x2 stud wall.
I would need to install complete newel posts as there aren't any newel posts present (and 2x2 is too small) for me to use peg newel posts. Is this possible to do with the staircase in situ or would it involve removing the whole staircase and starting again or even still installing a brand new staircase. I'm not very keen on removing the staircase or installing a brand new one.
Advice most welcome...
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: No newel posts
Post by ayjay »
Installing a newel post to an existing staircase is quite a challenging procedure for a diyer.
Is there no sign of an old newel post? If it's just been cut down it may not be too bad, but if it's not there at all you need to somehow achieve a strong joint between the string and the new newel. You might for example need to fit a loose tenon in the string to achieve a satisfactory joint.
Grendel
Has thanked: 200 times
Been thanked: 482 times
Re: No newel posts
Post by Grendel »
Perhaps a picture might help. Nothing is impossible , they just have varying degrees of difficulty.
Watchnlearn
Re: No newel posts
ayjay wrote:Installing a newel post to an existing staircase is quite a challenging procedure for a diyer.
No I don't think there are any newel posts at all. Loose tenon is beginning to sound complicated :scratch:
Grendel wrote:Perhaps a picture might help. Nothing is impossible , they just have varying degrees of difficulty.
I've attached some photos. Please ignore the crapet, we are currently renovating the house. From what is seen do you think it is possible?
