Make my own door linings.
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
I live in a 1950’s house. One of the previous owners has made a hack of some of the internal linings so I plan on ripping them out and building my own. It will be a fairly easy job in terms of fitting and installing as I know what I’m doing on that score i.e. levelling up using shims etc.
However I’m lacking some knowledge on the size of timber I should use. The width of the wall is 6”. Do I install a 6” piece of timber as a door lining and the door hinges fit directly on to the door lining or do I make the door lining oversize and another piece of planed timber say about an inch or so thick fits over the door lining and the door attaches on to this?
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Re: Make my own door linings.
6 x 1-1/4in with housed joints in the head, and something like 1-1/2in x 1/2in (finished) or so softwood laths for the stops - most timber yards would sell you something similar as "door stops, 1/2 hour". All PAR, all finished sizes
- These users thanked the author Job and Knock for the post:
- Argyll
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
What thickness were the ones you ripped out? They’ll have been 33mm or 45mm
Make sure you get the correct thickness as it’ll save a huge amount of packing or they’ll be too thick for opening.
- These users thanked the author steviejoiner74 for the post (total 2):
- Job and Knock • Argyll
- Rating: 14.29%
- Has thanked: 32 times
- Been thanked: 786 times
timber yard here always want to sell say 6 x 1 for door linings. dunno why its always wayyyy better with thicker 1 1/8 or 1 1/4 timber
- steviejoiner74
I’ve never used anything thinner than 33mm for door standards and it’s always 45mm for external or fire doors.
- These users thanked the author steviejoiner74 for the post:
- Argyll
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
you definately need at least 33mm you may get away with 25mm but planed timber will be around 20-21mm so 6x1" will actually be 20-21x143mm
wood from the sheds will actually be nearer 18-19mm
- Argyll
Thanks for the replies.
Is it option 1 or 2Do I install a 6” piece of timber as a door lining and the door hinges fit directly on to the door lining or do I make the door lining oversize and another piece of planed timber say about an inch or so thick fits over the door lining and the door attaches on to this?
- Door lining 2.pdf
- (83.31 KiB) Downloaded 203 times
- Door lining 1.pdf
- (83.33 KiB) Downloaded 179 times
- Job and Knock
You normally chop the hinge recesses directly into the door lining. I tend to install packers directly behind the hinges and at top and bottom (hinge side) and at 900 to 1000mm (i.e latch plate height), top, nbottom and half way between top and latch plate on the latch side. Maybe a bit OTT but stops the tendency for the legs to bow and supports the hinges fully.
- Argyll
