Another 'What's this for'?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
- Has thanked: 100 times
- Been thanked: 1022 times
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
- Has thanked: 94 times
- Been thanked: 857 times
Re: Another 'What's this for'?
you answered your own question it a measuring pole
ranging poles are usually white and red so they can be seen at distance
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Yes it is for measuring internal distances, as in ceiling heights like you said, window reveals, doorways, etc., etc. where it would be difficult to extend a flexible tape measure without an assistant.
I have a similar tool that has a tape measure built in to it, you just read off the distance through a small window.
No, not a survey pole.
- These users thanked the author arco_iris for the post:
- Job and Knock
- Has thanked: 1299 times
- Been thanked: 1175 times
Must say I didn't know what it is.
Quick look online, they ain't cheap to buy!
- Argyll
- Argyll
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
A stick? A pole?
Personally I'd use an ultrasonic distance meter.
- arco_iris
The one I have, which I found laying in the middle of a dual-carriage way nearly thirty years ago, is marked "Nedo Messfix" and extends to 5.00 metres.
Googling this they are still available! Described as a telescopic measuring stick.
http://www.nedo.com/index.pl?Lang=ENGLI ... ssfix.html
Way more accurate than ultrasonic, I'd have thought - don't trust those to be precise!
- Job and Knock
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Laser measures are more accurate and a lot smaller. Can't see me sticking one of those sticks in my tool belt, somehow
The longer ones are usually use on oversized loads for the Hight and width to make sure they comply with the permits (a part usually clips on the top - to hang it on the edgearco_iris wrote:The one I have, which I found laying in the middle of a dual-carriage way nearly thirty years ago, is marked "Nedo Messfix" and extends to 5.00 metres.
- arco_iris
Yes, but, j&k,
if you wanted to measure the precise distance between the handrails of the staircase in your picture, would you use a laser?
