Hi
Going to fit some Wickes softwood doors however they are only trimmable upto 12mm and I need to trim 2 of the doors by about 25mm, is this possible ?
I have trimmed their moulded doors by more than recommended and just added a bit of timber afterwards, obviously I can't do that to softwood doors.
trimming wickes softwood doors
- Has thanked: 100 times
- Been thanked: 1022 times
Re: trimming wickes softwood doors
If you trim that much the door will likely look way out of proportion. Can you not just buy a smaller door so it requires less trimming?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
the trouble is the can be any old carp in the core made up from hundred off staves can also be chipboard or other core with just veneers on the face and timber added round the edges
do you have an actual description
- big-all
- Pro Carpenter
you may have a presentable edge you may not no way off telling till you trim it
you may have mismatched timbers even different species or hollows or gaps
what tools do you have??
circular saw remove a 4-6mm lip off each side the reapply if required after shooting in assuming edge is fairly flat
