Looking to wire outdoor lights and sockets as per diagram below.
Just checking if I need 7 core from bottom gate up to middle left gate or is 5 core ok?
Basically I want all lights either on or off and also outdoor sockets.
NB: not wiring this myself, just supplying the items and wondering if I really need 5 and 7 core cable
Wiring Outdoor Lights and Sockets
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: Wiring Outdoor Lights and Sockets
Your drawing is too small for these old tired eyes
But you could answer some questions.
What exactly are you wanting to do and what is 5 or 7 core cable doing ? / what's it for?
Generally sockets are wired in 2.5 mm cable and lights 1mm cable, so 5 or 7 core comes into question
7 core cable is only 0.75 mm (way too small)
Believe it or not you can get 2.5mm 5 core cable, but its flex.
You can't use the earth that the sockets are on for the lights.... unless the lights are fed fed via an FCU first.
yep, bigger drawing - please
- Approved Electrician
- Has thanked: 223 times
- Been thanked: 657 times
Download the photo and open it in Photos.someone-else wrote:Your drawing is too small for these old tired eyes
- Someone-Else
wish I hadn't. I can't read the writing.
I think it says SWA which is fine, but i don't understand the drawing, but then again, if that has what the electrician doing the job has designed then who am i to argue?
- Someone-Else
OnlyMe wrote:Nor could I
